914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Ok, here we go again. I already posted the story about the cost of the paint and shipping. So paint came in this afternoon. Had parts prepped for paint, did a spray out of two coats. Paint is NOT the correct color. I have several NOS exhaust pieces and they are all the same color as heater duct piece shown.
Piece 1 is with stock gray VHT 900* from Home Depot Piece 2 is two coats of Stoddard Exhaust paint Piece 3 is NOS stock color Side side comparison. I think the local paint store might be able tomix up you something better Attached image(s) ![]() ![]() ![]() ![]() ![]() |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Thanks for the heads up
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,549 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
I wonder how exact Porsche's color spec was on the paint. And if your NOS part darkened with age. Why not paint the parts with the paint you got and they all match. No one but you will know.
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
That coating darkens over time. I’d go with the Stoddard.
johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
Mark...I think really this paint was developed for the 911 and 356 mufflers. It matches that pretty well.
We use to use RUST-OLEUM 7785-830 COLD GALVANIZING COMPOUND SPRAY before the Stoddard stuff was available to get a similar color...sprayed it and then take torch and "cook" it in. As Jeff said the Stoddards does darken a little after heat curing. |
pete000 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States ![]() |
All three are grey, good enough for me...lol
wonkipop |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,440 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille ![]() ![]() |
I wonder how exact Porsche's color spec was on the paint. And if your NOS part darkened with age. Why not paint the parts with the paint you got and they all match. No one but you will know. exactly reckon stoddards have it pretty right. can remember getting VW exhaust pieces back in early 80s. mid grey like stoddards. NOS parts are half a century old. paint changes color with time. parts have aged just like cars. angst over restoration has to be in perspective. reference parts are not fresh parts. folks who restore paintings can tell you about it. sistine chapel ceiling turned into a muddy turgid dark thing over 3 centuries. but when michelangelo painted it first up, was very bright. can tell you grey does one of two things, depending on the base used to mix it. if its a white base it fades over time to white. if its out of a black base it darkens over time to black. the pigments fade out. i can only find the original phoenix red on my car on the inners. and boy is it lurid. the outside still looks bright and 70s but its half way to faded and gone out of the world. |
914Sixer |
Yes, I am going to over look it the difference and move on. It is just I expected the paint to be a lot closer.
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
914Sixer |
OK, looks like it is going to need some heat.
Lo-Fi Version | Time is now: 26th June 2024 - 06:32 AM |
