Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,483 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Building a 2056 with a 9550 cam, Ljet with 912 injectors. Any mods need to be done to the AFM?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,596 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The 912e runs this setup. The fuel map is set up for a 1.8 on the 914 box, if you have any problems look for a 912e box.
There may be a few around as many did go to carbs. They were seen as an upgrade at one time. Funny with the 2.0 L jet configuration the 912e get about 25-30 mpg. One of the reasons most have a lot of miles on them. |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
To be absolutely sure, you’ll need to monitor the fuel air mixture in the exhaust.
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
I would think you should check the air/fuel ratio with a O2setup after getting it running with that cam. On my Westy I had to adjust the afm richer
hcdmueller |
????????????? ![]() ![]() ![]() Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England ![]() ![]() |
I would think you should check the air/fuel ratio with a O2setup after getting it running with that cam. On my Westy I had to adjust the afm richer (IMG:style_emoticons/default/agree.gif) I built a camper special 2.0l for my last bus and definitely needed some adjustments on the AFM. |
Lo-Fi Version | Time is now: 1st July 2024 - 02:16 PM |
