Roll bars/half cage installs, Show me what you have. |
Luke M |
Apr 8 2021, 07:28 AM
Senior Member Group: Members Posts: 1,400 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
My brother wants to add a half cage to his 914. Any info from anyone running one would be greatly appreciated. Pro's and con's that you may have experienced?
Weld in or bolt in.. Either way works for us but leaning towards welding it in. TIA.. (IMG:style_emoticons/default/beerchug.gif) |
Mark Henry |
Apr 8 2021, 07:49 AM
Racer Chris isn't too faŕ from you.
IIRC McMark was doing GT kits, nice one that contoured the firewall. But that was a long time ago. If it's a part time racer street car you want to be able to use the stock seat belts, the 5 points are a PITA for every day use. |
Luke M |
Apr 8 2021, 07:57 AM
Racer Chris isn't too faŕ from you. IIRC McMark was doing GT kits, nice one that contoured the firewall. But that was a long time ago. If it's a part time racer street car you want to be able to use the stock seat belts, the 5 points are a PITA for every day use. Mostly a street car but some auto-x time as well. I pm'd Mark about his cage. Think he was planning on a 5 point harness anyways. |
tygaboy |
Apr 8 2021, 08:40 AM
914 Guru Group: Members Posts: 5,477 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
I vote weld in. I helped a buddy with his bolt-in GT bar and didn't like the way it forced the bar to be set forward - you give up some room.
Given that, you can't go wrong with @ChrisFoley products, assuming you don't want to fab your own. I went a bit non-traditional with my design as I didn't want a full main hoop and did things like relocating my seatbelt retractors so I'm not sure these pics help but maybe will give some ideas. I call it "the roadster cage". Attached image(s) |
VegasRacer |
Apr 8 2021, 08:58 AM
ELVIRA Group: Benefactors Posts: 8,709 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Maybe these pictures will help. Photos are not my car. I have a full cage.
Attached image(s) |
Racer |
Apr 8 2021, 09:13 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
One of my 914s had a Safety Devices cage. It was welded in, but they are bolt in/weld in friendly.
Street car.. Used for DE/Autocross. Biggest gripe? Made taking the roof on and off a bit more PITA.. and more often than not, I just left the top in place Ran both harnesses and factory belts. No door beam supports like some of the above have. Not sure how much that actually helps in an impact.. or if they would bend in and cause more harm than good. Remind me of the "pro Street" type 1/4 miile cars with albeit rule complying but curious designs. A half cage/ merely a rollbar hoop I also wonder how much rigidity is added to the chassis vs the additional weight. I had some pictures on an old photobucket site.. not sure if I they are still accessible.. http://www.safetydevices.com/motorsport/pr...+Spec/451/1276/ The other issue you will notice is that room to swing your feet in and out is cut down with a 4/6pt cage. |
Steve |
Apr 8 2021, 09:21 AM
914 Guru Group: Members Posts: 5,771 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Shivers |
Apr 8 2021, 09:25 AM
Senior Member Group: Members Posts: 2,846 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I think one of these half cages would be perfect. With the foam is it streetable? Or is it a headbanger
Luke M |
Apr 8 2021, 09:42 AM
VegasRacer |
Apr 8 2021, 10:12 AM
With the foam is it streetable? Or is it a headbanger Yes. it is streetable. Yes the foam really helps. The only time I bang my head is when I am working on the car. Never during regular use. Something like the last two pics. That car belongs to @1stworks |
infraredcalvin |
Apr 8 2021, 01:23 PM
Distracted Member Group: Members Posts: 1,577 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I have a safety devices bolt in cage that was welded in by PO. The supports that go diagonal to the center hump (like the gt) limit race seat travel. Ok for me, but I’m short at 5’8”. I’d be concerned about leg room at 6’0”. I’ve seen versions that don’t have the center diagonal.
Also, the bar in front horizontal is set rearward from the top of windshield (assuming they did it so it wouldn’t interfere with lid latches). Being short, my seat is moved forward, which puts that horizontal bar near my head, my helmet grazes the pad. I lowered my seat by cutting out the floor cross support and it’s fine now, but not a mod I would want to make on a nice car... |
tazz9924 |
Apr 8 2021, 01:34 PM
Senior Member Group: Members Posts: 716 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Weld in cages are always preferable to bolt in from a safety stand point, and like chris said you get more room. If you cant find any prebent stuff it probably wouldn’t cost much to have a reputable shop make a half cage. especially if you strip the stuff out the way. If it hasn’t been mentioned your back pad will be sacrificed.
mlindner |
Apr 8 2021, 01:44 PM
Senior Member Group: Members Posts: 1,598 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Luke M |
Apr 9 2021, 07:16 AM
A full cage is out at this point. Leaning towards Mark's cage with maybe a tweek or two to it. Like this one but with some bent side supports to make it easier to get in/out. Seams like the seat would be able to go back a little farther.
@McMark Attached image(s) |
bkrantz |
Apr 9 2021, 08:22 PM
914 Guru Group: Members Posts: 8,192 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Whatever you get, buy some real roll bar padding for anything near your head. Not the cheap open cell split foam tubes.
Tdskip |
Apr 11 2021, 02:22 PM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Even "just" a weld in rear hoop makes a noticeable difference.
Justinp71 |
Apr 12 2021, 01:42 PM
Senior Member Group: Members Posts: 1,606 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Plan your harness mounting along with putting in your half cage. Many times they tie together or may need to not interfere with each other. Might as well plan for racing seats too, they all need to work together.
The half rollbar I have allows the driver seat to go all the way back which is important for me at 6'0". I need to upgrade my padding to the harder SFI stuff. The half rollbar itself its probably not really needed, but makes be feel better incase of a roll at track events. Attached image(s) |
LefthandRev |
Dec 10 2023, 11:42 AM
Member Group: Members Posts: 82 Joined: 9-August 21 From: Seattle, WA Member No.: 25,787 Region Association: Pacific Northwest |
mlindner |
Dec 11 2023, 10:13 AM
JmuRiz |
Dec 11 2023, 11:27 AM
914 Guru Group: Members Posts: 5,518 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
If he wants a full cage, let me know...my brother took his out.
DC area... I sold my roll bar a couple years back. |
Lo-Fi Version | Time is now: 4th January 2025 - 07:49 PM |
