Finding Oil Leaks |
Finding Oil Leaks |
brian minson |
Apr 8 2021, 01:55 PM
Newbie Group: Members Posts: 27 Joined: 10-May 17 From: Gilbert, Arizona Member No.: 21,089 Region Association: Southern California |
Hey guys I have three leaks under my T4 2.0 engine, seems to be pushrod tubes but maybe not.
I have used the engine oil dye in my non-Porsche cars over the years with success but didn't know if there were any tips or tricks to tracking down my oil leaks in the Type 4. Suggestions or etc? Brian (IMG:style_emoticons/default/smile.gif) |
porschetub |
Apr 8 2021, 02:35 PM
Advanced Member Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hey guys I have three leaks under my T4 2.0 engine, seems to be pushrod tubes but maybe not. I have used the engine oil dye in my non-Porsche cars over the years with success but didn't know if there were any tips or tricks to tracking down my oil leaks in the Type 4. Suggestions or etc? Brian (IMG:style_emoticons/default/smile.gif) My method has always worked for leaks,get the engine fully clean underneath then place a sheet of white cardboard under the motor,run up to temp without driving,the oil leaks will show up on the cardboard and give a reasonable indication of the source. I used this method on my 911 engine and found many of the leaks weren't where I thought they were. Good luck. |
ctc911ctc |
Apr 8 2021, 05:25 PM
Senior Member Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
I chased a leak for years - guys on this board said to drop motor and replace all seals. I ignored them and even went through the pain of replacing the oil cooler seals WITHOUT dropping the engine. We should award a badge to those who have done this. (grease on the wrench to get the gasket in place and having it drop in your face.....5 times)
Finally, I pulled the engine, Cleaned the heck out of it (first drop for the car) replaced ALL of the seals (front/back/tubes/cooler/oil-pressure) and while I was at it I opened the tranny and replaced sync rings.....down shifting to first is a true joy now..... I have not had a leak or a drip or a seep in 9 months......ahhhhhhhhhhhh Feels so good I am having a beer! (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/coffee.gif) (IMG:style_emoticons/default/silver914.jpg) Hey guys I have three leaks under my T4 2.0 engine, seems to be pushrod tubes but maybe not. I have used the engine oil dye in my non-Porsche cars over the years with success but didn't know if there were any tips or tricks to tracking down my oil leaks in the Type 4. Suggestions or etc? Brian (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 06:01 AM |
