euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
EDIT: I found a bolt that will work for now. Thanks for the replies (IMG:style_emoticons/default/beerchug.gif)
The replacement strut I'm installing on HOWARD is missing the pinch bolt to secure the ball joint. Anybody have a spare one laying around? |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Standard 12.9 bolt
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
mskala |
I found the box. Also confirmed looking at Pelican. The proper bolt is M10 x 30mm, grade 10.9 (though higher is not a problem).
If you can't get that at a local hardware store I can send you a pair. |
euro911 |
I found a 10x30mm stainless bolt in my stash that will do the trick for now. I just needed to get the ball joint clamped in so the car can get winched up onto a trailer. When the other repairs are done, I have a pair of 'late' struts earmarked for installation.
Thanks for all the replies, guys (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Yea, it’s good to have extra suspension parts to make a tub a roller.
euro911 |
Yea, it’s good to have extra suspension parts to make a tub a roller. In retrospect, I should have kept those trailing arms that I sent your way, Mark (IMG:style_emoticons/default/laugh.gif) ![]() ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 07:38 AM |
