rosenfe |
Senior Member ![]() ![]() ![]() Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None ![]() |
I know how to get the plastic switch out, but not sure how to remove metal tumbler with key. I’ve searched and can’t find any info
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
@rosenfe
Disconnect positive terminal to battery. Remove lower dash to access switch plugs. Pull connectors for ifnition, wiper and turn signals. Pull steering wheel. Pull turn signal and wiper swithes. Washers hoses may need to be cut to pull wiper switch. Remove two screws to cover for ignition switch. Insert key and turn to ON pisition position. Pull tumbler assembly out of housing |
Lo-Fi Version | Time is now: 18th June 2024 - 07:58 AM |
