Color blind, And forgetful |
Front yard mechanic |
Jul 7 2021, 10:53 PM
Senior Member Group: Members Posts: 1,243 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
falcor75 |
Jul 7 2021, 11:06 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Yellow
ClayPerrine |
Jul 8 2021, 06:19 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
It is yellow, and goes into either of the rear two spade connectors on the left rear side of the relay board.
It tells the double relay on the L-Jet that the starter is engaged so it can turn the fuel pump on. And just a tip.. you can put a spade connector on either of those connections and feed it 12v to make the engine crank. That helps if the ignition switch fails on a trip. |
mate914 |
Jul 8 2021, 06:39 AM
Matt Group: Members Posts: 802 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
The red one has an issue, cut or sliced maybe (IMG:style_emoticons/default/flag.gif) .
Matt |
Jul 8 2021, 07:21 AM
Thanks I was unsure . The front spades test positive and I didn't want to fry something. Do I even need to use this if I'm running carbs?
burlybryan |
Jul 8 2021, 08:59 AM
Member Group: Members Posts: 118 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
Ansbacher |
Jul 8 2021, 10:18 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Agreed- I have carbs too and nothing goes to those spades.
So, Clay: Are you saying I could run a wire from one of those spades to the battery, interrupting it with a momentary switch, and I would have an emergency ignition cranking switch in the engine bay? If true, how cool is that. Ansbacher |
Jul 8 2021, 12:33 PM
thanks for the help im inspired now and searched for a better solution to wire my fuel pump and found a great "how to wire for carbs" (IMG:style_emoticons/default/smilie_pokal.gif) Andy & Perry
ClayPerrine |
Jul 8 2021, 12:40 PM
Agreed- I have carbs too and nothing goes to those spades. So, Clay: Are you saying I could run a wire from one of those spades to the battery, interrupting it with a momentary switch, and I would have an emergency ignition cranking switch in the engine bay? If true, how cool is that. Ansbacher That is 100% true. I have a spade connector on a short piece of wire that I use when hooking a remote starter button to Betty's car. It is far easier than crawling underneath. Clay |
StarBear |
Jul 9 2021, 07:03 AM
Advanced Member Group: Members Posts: 2,085 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Agreed- I have carbs too and nothing goes to those spades. So, Clay: Are you saying I could run a wire from one of those spades to the battery, interrupting it with a momentary switch, and I would have an emergency ignition cranking switch in the engine bay? If true, how cool is that. Ansbacher That is 100% true. I have a spade connector on a short piece of wire that I use when hooking a remote starter button to Betty's car. It is far easier than crawling underneath. Clay @ClayPerrine Could you post a sketch schematic, wire gauge and type of switch? I’d really like to do this “hack” but don’t want to fry something. Also, hoping Betty’s car is coming along well; if you need a replacement 1.8 engine tuneup sticker (see Originality Forum) let me know and I’ll mail you one. Thanks for all you do on the Forum. |
mate914 |
Jul 9 2021, 07:10 AM
I am also interested in this. Having a Double spine fusion issue, this would be very use full.
Matt (IMG:style_emoticons/default/flag.gif) Agreed- I have carbs too and nothing goes to those spades. So, Clay: Are you saying I could run a wire from one of those spades to the battery, interrupting it with a momentary switch, and I would have an emergency ignition cranking switch in the engine bay? If true, how cool is that. Ansbacher That is 100% true. I have a spade connector on a short piece of wire that I use when hooking a remote starter button to Betty's car. It is far easier than crawling underneath. Clay @ClayPerrine Could you post a sketch schematic, wire gauge and type of switch? I’d really like to do this “hack” but don’t want to fry something. Also, hoping Betty’s car is coming along well; if you need a replacement 1.8 engine tuneup sticker (see Originality Forum) let me know and I’ll mail you one. Thanks for all you do on the Forum. |
ClayPerrine |
Jul 9 2021, 11:16 AM
I just use a short piece of wire, an a spade connector. I use my blue-point remote starter button I have owned for years as the switch. It just has alligator clips on the end of the wires.
The switch kinda looks like this.... |
StarBear |
Jul 9 2021, 02:58 PM
I just use a short piece of wire, an a spade connector. I use my blue-point remote starter button I have owned for years as the switch. It just has alligator clips on the end of the wires. The switch kinda looks like this.... @ClayPerrine . So this switch connects the positive terminal to the wire with the spade connector? Any particular gauge wire (8)? Just checking so as not to fry things. |
ClayPerrine |
Jul 10 2021, 06:39 PM
I just use a short piece of wire, an a spade connector. I use my blue-point remote starter button I have owned for years as the switch. It just has alligator clips on the end of the wires. The switch kinda looks like this.... @ClayPerrine . So this switch connects the positive terminal to the wire with the spade connector? Any particular gauge wire (8)? Just checking so as not to fry things. One alligator clip goes to the positive battery post. The other connects to a piece of wire with a spade connector, and the spade connector is plugged into the relay board on one of the rear two connectors of the 4 pin connector on the left rear. I just matched the wire size with the yellow wire that attaches to the spade connector on the starter. Clay |
StarBear |
Jul 11 2021, 08:31 AM
I just use a short piece of wire, an a spade connector. I use my blue-point remote starter button I have owned for years as the switch. It just has alligator clips on the end of the wires. The switch kinda looks like this.... @ClayPerrine . So this switch connects the positive terminal to the wire with the spade connector? Any particular gauge wire (8)? Just checking so as not to fry things. One alligator clip goes to the positive battery post. The other connects to a piece of wire with a spade connector, and the spade connector is plugged into the relay board on one of the rear two connectors of the 4 pin connector on the left rear. I just matched the wire size with the yellow wire that attaches to the spade connector on the starter. Clay Thanks! Off to my FLAPS... |
rgalla9146 |
Jul 11 2021, 09:04 AM
Advanced Member Group: Members Posts: 4,671 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Great idea Clay Some vintage English cars had a built in under-hood starter button. Can be very handy for tune-up and maintenance work. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:47 AM |
