Back up light switch on tranny, Maybe a dumb question |
burlybryan |
Jul 8 2021, 08:05 AM
Member Group: Members Posts: 118 Joined: 25-May 20 From: Saint Paul Member No.: 24,311 Region Association: None |
I have no reverse/backup lights. Jumpering the wires on the tranny mounted switch gets them to come on, so I figure the wiring is ok and the switch is flaky. I have no knowledge about the internals of our trannys, so before I replace it I wanted to verify if the switch is immersed in fluid or dry. If wet, I'd just plan a gear oil change as part of the process.
Thanks for any insight. Bryan |
76-914 |
Jul 8 2021, 08:11 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Unscrew it. There is a 6mm pin that wears down. Probably the culprit. You can fab another one from th shank of a 6mm bolt or get in touch with @bdstone914 on this site for another unit. (IMG:style_emoticons/default/beerchug.gif)
Shivers |
Jul 8 2021, 08:16 AM
Senior Member Group: Members Posts: 2,825 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
it sits right around the same height as the filler plug on the other side. Put a pan under it, have everything clean, screw out old part then screw in new part. Then if you did lose a bit add it in the filler plug if the amount makes you uncomfortable.
bdstone914 |
Jul 8 2021, 08:23 AM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Unscrew it. There is a 6mm pin that wears down. Probably the culprit. You can fab another one from th shank of a 6mm bolt or get in touch with @bdstone914 on this site for another unit. (IMG:style_emoticons/default/beerchug.gif) @burlybryan @76-914 It is smaller than 6mm. I think it is 3 or 4mm. Just buy a new one for $20 from Porsche or Pelican. Thanks for the referral but i dont think i have any and not worth reusing. Part number 90530324502 |
914Sixer |
Jul 8 2021, 08:24 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
URO makes a replacement part. About $4 Cheap insurance. Screenshot from Rockauto, click to open
Attached thumbnail(s) |
burlybryan |
Jul 8 2021, 08:26 AM
Thanks guys! Perfect information. Makes sense that it's about level with the fill plug.
I have a new switch and tang/rod already, so I should be good to go. Bryan |
Lo-Fi Version | Time is now: 26th December 2024 - 11:29 PM |
