It tried to "eat" the fan belt |
SKL1 |
Jul 9 2021, 11:07 AM
Senior Member Group: Members Posts: 1,646 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Was timing my '71 yesterday and everything seemed fine until I was going to take it for a short drive, and when revving it, it just sounded funny and fan definitely sounded different. Shut it off and when checking the fan, by feel obviously, it was totally twisted on the alternator pulley.
Been doing this for 51 years and never had that happen before. Used a new belt and thought tension was ok. Belt from pelican so should be the right part and length seemed fine when adjusting tension... ??? |
wndsrfr |
Jul 9 2021, 05:13 PM
Senior Member Group: Members Posts: 1,441 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Was timing my '71 yesterday and everything seemed fine until I was going to take it for a short drive, and when revving it, it just sounded funny and fan definitely sounded different. Shut it off and when checking the fan, by feel obviously, it was totally twisted on the alternator pulley. Been doing this for 51 years and never had that happen before. Used a new belt and thought tension was ok. Belt from pelican so should be the right part and length seemed fine when adjusting tension... ??? Something is off in the alignment of the alternator...carefully check the bracket bolt at the back end of the alternator... if it's loose it'll allow it to twist....might need another new belt after this one is abused... |
r_towle |
Jul 9 2021, 09:32 PM
Custom Member Group: Members Posts: 24,663 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Get a mirror and flashlight.
Make sure a rag or tool did not fall into the area the fan is located. A rag can take the fan belt clean off...only takes a second. Rich |
Lo-Fi Version | Time is now: 27th December 2024 - 10:48 AM |
