Searching for info on removing blower motor in front trunk |
rosenfe |
Jul 9 2021, 03:51 PM
Senior Member Group: Members Posts: 564 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I’ve tested blower with power to plug 1 and nothing. I suspect it’s dead. I’ve searched on how to remove blower. Can’t find anything. This is for a 69
914sgofast2 |
Jul 9 2021, 04:05 PM
Senior Member Group: Members Posts: 655 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I’ve tested blower with power to plug 1 and nothing. I suspect it’s dead. I’ve searched on how to remove blower. Can’t find anything. This is for a 69 Check Ian Karr’s YouTube channel for how to remove the blower motor and fresh air box. It’s one of the 914 Rites of Passage. |
Steve |
Jul 9 2021, 04:09 PM
914 Guru Group: Members Posts: 5,766 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I’ve tested blower with power to plug 1 and nothing. I suspect it’s dead. I’ve searched on how to remove blower. Can’t find anything. This is for a 69 Check Ian Karr’s YouTube channel for how to remove the blower motor and fresh air box. It’s one of the 914 Rites of Passage. (IMG:style_emoticons/default/agree.gif) I was able to get it out, but I could not get it back in without Ian's video. We purchased the special tool at Harbor Freight and used giant rubber bands from Hobby Lobby and got it back in per Ian's video. We also used 914rubbers new grill and rubber. |
bkrantz |
Jul 9 2021, 08:02 PM
914 Guru Group: Members Posts: 8,175 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Some ideas from memory:
1. Take lots of pictures, especially where all the control cables go. Maybe label the cables. And make some diagrams. And take pictures. 2. Remove the air duct hoses. 3. Remove the cowl braces. 4. Undo the bolts, one on each side that hold the air box in place. 5. Pull the air box and blower forward while pulling the cowl upward. It helps to be VERY strong and VERY careful. Of course, all this assumes you have removed the fuel tank. |
iankarr |
Jul 11 2021, 04:30 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,526 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
@Steve glad the video was helpful!
porschetub |
Jul 11 2021, 05:55 PM
Advanced Member Group: Members Posts: 4,754 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Some ideas from memory: 1. Take lots of pictures, especially where all the control cables go. Maybe label the cables. And make some diagrams. And take pictures. 2. Remove the air duct hoses. 3. Remove the cowl braces. 4. Undo the bolts, one on each side that hold the air box in place. 5. Pull the air box and blower forward while pulling the cowl upward. It helps to be VERY strong and VERY careful. Of course, all this assumes you have removed the fuel tank. Good points,I ripped down a piece of wood on my table saw and packed up the air box that way which was great as I was getting pretty pissed off before doing that (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . I didn't remove the bonnet as I had fresh paint but for this job it would have easier if its removed,you can get the fuel tank out with bonnet on however no issue . Its a bastard job but you get there in the end,my airbox had a new body seal so IMO it made it harder. Good luck. |
NARP74 |
Jul 13 2021, 01:53 PM
Senior Member Group: Members Posts: 1,300 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I’ve tested blower with power to plug 1 and nothing. I suspect it’s dead. I’ve searched on how to remove blower. Can’t find anything. This is for a 69 How do you test it? I just added another project to my never ending list. My blower is not working either! I did check the fuse in the engine bay. If I read it right, it shares the fuel pump power and the pump runs. |
Lo-Fi Version | Time is now: 27th December 2024 - 09:12 AM |
