1975 Harness Question |
simonjb |
Jul 9 2021, 05:30 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I have a 1975 1.8 that does not have the appearance package. I am keeping the car all stock - but I would like to add Oil pressure/Temp gauges and voltage.
Does the stock harness include any of these connections where the console would be? |
bdstone914 |
Jul 9 2021, 06:19 PM
bdstone914 Group: Members Posts: 4,735 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a 1975 1.8 that does not have the appearance package. I am keeping the car all stock - but I would like to add Oil pressure/Temp gauges and voltage. Does the stock harness include any of these connections where the console would be? Definitely not oil pressure. No 914 had oil pressure gauges. I though all the cars had the wiring for the console gauges after 72. @IRONHILLRESTORATIONS mentioned a wire that can be repurpised for oil pressure. Possible rear window defroster. You can pull up your caroet and see if the connectors are by the tunnel for console gauges. |
914Sixer |
Jul 10 2021, 06:18 AM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
All the plugs are there for the clock, temp and volt gauges. You can use the hot and ground from clock to power any other gauge you want to install.
simonjb |
Jul 10 2021, 07:02 AM
Thanks very much
IronHillRestorations |
Jul 10 2021, 07:49 AM
I. I. R. C. Group: Members Posts: 6,792 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I have a 1975 1.8 that does not have the appearance package. I am keeping the car all stock - but I would like to add Oil pressure/Temp gauges and voltage. Does the stock harness include any of these connections where the console would be? Definitely not oil pressure. No 914 had oil pressure gauges. I though all the cars had the wiring for the console gauges after 72. @IRONHILLRESTORATIONS mentioned a wire that can be repurpised for oil pressure. Possible rear window defroster. You can pull up your caroet and see if the connectors are by the tunnel for console gauges. That’s for a 6. On a 6 conversion you can use the heater blower switch wire. For an OP gauge you’ll have to run a wire |
Lo-Fi Version | Time is now: 26th December 2024 - 08:09 PM |
