Taco Plate |
Taco Plate |
simonjb |
Jul 10 2021, 08:52 AM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I've been searching the site - but I need some confirmation. My 1975 1.8 Non-appearance did not come with an Oil Temp Gauge.
Can I add a Tuna can set up and sending unit ? I think there should be a wire wrapped up under the battery support? For CHT I was going to get a spark plug Ring For Oil Pressure - get an adapter and sending unit to also keep dummy light |
914werke |
Jul 10 2021, 09:01 AM
"I got blisters on me fingers" Group: Members Posts: 11,030 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
You are confusing a couple of our "nicknames" (IMG:style_emoticons/default/smile.gif)
The Tuna can is a mini-sump that mounts at the center botom of your case & extendes the oil PU into a resevior of oil to prevent starvation during hard cornering. The TACO PLATE is the nickname for the Oil tempeture sender on the bottom-front (left) of the case that sends the signal to a guage in console or combo gauge. Called a "Taco Plate" because the OE part was made from a thin stamped steel that commonly gets over tightened (into the shape of a Taco) to eliminate an oil leak only to make it worse! Yes. A green w/red strip wire should be present eminating from the main loom just under the battery tray. |
simonjb |
Jul 10 2021, 09:39 AM
Sorry about that !! Too many T’s. So can I add a taco plate and install a sender unit ?
SirAndy |
Jul 10 2021, 10:13 AM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
914werke |
Jul 10 2021, 11:02 AM
Attached image(s) |
914werke |
Jul 10 2021, 11:06 AM
Sorry about that !! Too many T’s. So can I add a taco plate and install a sender unit ? Absolutely. First check that you dont already have one installed (IMG:style_emoticons/default/shades.gif) If not you will have a blank plate in its place. Im biased, so Id consider the billet unit I offer over the OE piece unless you want to keep it all original. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 27th December 2024 - 02:04 AM |
