> Frunk Question
Thunderchief
post Jul 15 2021, 02:02 PM
My unfinished restoration came with all of the weatherstripping which fits well except for the frunk. It seems too thick which makes the frunk hard to close. Anybody else have this problem?
StarBear
post Jul 15 2021, 02:13 PM
Rather typical. Fit/squeeze it in then shut hood to compress without bending the hood, of course. Most times it styles in.
Steve
post Jul 15 2021, 02:38 PM
If your referring to the single strip in front of the gas tank, most of the aftermarket rubber strips are too high and cause the trunk lid to bend and harder to close. I bought a factory rubber strip for that part and aftermarket for the other piece that goes around the whole trunk.
Cairo94507
post Jul 15 2021, 02:54 PM
Michael
Yup- Steve nailed it. Did the same on my car. (IMG:style_emoticons/default/beer3.gif)
Thunderchief
post Jul 15 2021, 08:00 PM
I pulled that piece off and it did the trick. Thanks guys!
worn
post Jul 15 2021, 08:32 PM
can't remember
QUOTE(Cairo94507 @ Jul 15 2021, 12:54 PM) *
Yeah. Replaced all of the gaskets and now the frunk only opens when the weather is cool. Only 914 rubber parts I have had trouble with. Mostly I get it to work just fine.
Chris914n6
post Jul 16 2021, 02:24 PM
Jackstands are my life.
Same problem with the 914rubber divider seal. Lubed the contact patch with silicone (armor all) and it works fine now.
dr914@autoatlanta.com
post Jul 16 2021, 02:36 PM
should be fine if a factory or URO part. Please make sure that the hood line is correct, you could get the front hood hinge brackets too low and it will compress the seal too much. When the hood is closed seal or no seal it should be perfectly in align with the cowl and the fenders
QUOTE(Thunderchief @ Jul 15 2021, 01:02 PM) *
worn
post Jul 16 2021, 03:26 PM
can't remember
QUOTE(dr914@autoatlanta.com @ Jul 16 2021, 12:36 PM) *
Nope. My frunk lid sits just a bit proud all the way around. Similar problem after replacing seals for the rear trunk. Too much of a good thing. Three years haven’t cured the problem.
914Sixer
post Jul 17 2021, 08:17 AM
Another factor could be the rubber compound is more dense and does not collapse at the same rate as the original factory material. Ran into this problem with e brake boots. New rubber not pliable enough to go over bracket.
- Lo-Fi Version Time is now: 26th December 2024 - 10:39 PM
