jims914 |
Member ![]() ![]() Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region ![]() ![]() |
Any one have a good time replacing the mirror on the outside mirror.
any replacement parts ? |
dhuckabay |
Member ![]() ![]() Group: Members Posts: 224 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest ![]() ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Check out one of our sponsors: 914 Rubber
jims914 |
Thanks for the respond. The glass is no problem, it's the the inner mirror grommet and outer black retainer seal. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Check over at Auto Atlanta, thinking George had those parts. If not listed call and check with them.
Arno914 |
Member ![]() ![]() Group: Members Posts: 233 Joined: 13-May 20 From: near Frankfurt, Germany Member No.: 24,260 Region Association: Germany ![]() ![]() |
There is a difference between early (up to 71) and later side mirrors.
Early ones are about 5mm shorter (less wide). Should have different glass, too. I finally "found" a ´71 914 with the stock mirror to prove this. Also note that the 90° arm is not "round" but more "angular". (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1626968976.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/up.picr.de-24260-1626968980.2.jpg) |
Lo-Fi Version | Time is now: 26th June 2024 - 04:19 AM |
