fduval |
Newbie ![]() Group: Members Posts: 41 Joined: 2-January 13 From: quebec Member No.: 15,331 Region Association: Canada ![]() |
Looking for one or two 8 x 16 Fuchs or nice replica ´s. must be straight , let me know if someone have these available, regards
Francois |
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,567 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
Do you want a 951 style 8x16 Fuchs or a 911 style 8x16 Fuchs wheel?
Bob B Burton The 8 x 16 Inch 911 part number cost a lot more |
fduval |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
The 851 wheel is offset an inch to the inside. It’s from a 944 turbo but let’s you run a 8x16 on the front of a 911.
fduval |
mepstein |
The 851 wheel is offset an inch to the inside. It’s from a 944 turbo but let’s you run a 8x16 on the front of a 911. Ok , and if I want to run 951 8 x 16 in the rear of a 911 , I need to use spacers right ? I’m not sure. Sorry. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
The 944 turbo wheel has the correct offset to fit the rear of a flared 914 with no issues.
Clay |
burton73 |
The look from the outside looks like the 7 inch x 16 inch
Let me see what I have in old pictures. I have been over this a few times over the last 10 years. Also the price for 8 inch x 16 911 wheel in real Fuchs is very high. Way more than a 8 x 15 If you are not running huge brakes it is much less money to put on the 15 in 7 and 8 Fuchs. Bottom Right 8x16 only factory Fuchs Bob B ![]() ![]() |
fduval |
The look from the outside looks like the 7 inch x 16 inch Let me see what I have in old pictures. I have been over this a few times over the last 10 years. Also the price for 8 inch x 16 911 wheel in real Fuchs is very high. Way more than a 8 x 15 If you are not running huge brakes it is much less money to put on the 15 in 7 and 8 Fuchs. Bob B Actually I have a set of 4 7 x 16 and trying to make a complete set of 7 & 8 x 16 Thanks for the advice , much appreciated. Francois |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Do you want a 951 style 8x16 Fuchs or a 911 style 8x16 Fuchs wheel? Bob B Burton The 8 x 16 Inch 911 part number cost a lot more Is the difference very noticeable? I would prefer 911 style . Let me know. Thks As I recall the recess for the lugs on the 951 is much larger |
fduval |
Do you want a 951 style 8x16 Fuchs or a 911 style 8x16 Fuchs wheel? Bob B Burton The 8 x 16 Inch 911 part number cost a lot more Is the difference very noticeable? I would prefer 911 style . Let me know. Thks As I recall the recess for the lugs on the 951 is much larger Yes I recall that too,. Thks |
burton73 |
Pictures of my wheels on my 6 #41
7 and 8 x 16 inch 911 part numbers with Rs finish done by fuchsrestoration.com they have finished several sets for me in the past. You will find that 911 part number 8x16inches will cost you a lot of money. Bob B ![]() ![]() |
fduval |
Still looking thanks
Lo-Fi Version | Time is now: 26th June 2024 - 12:46 AM |
