grantsfo |
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None ![]() |
Anyone have ideas on sources for lightweight 914 doors that would allow stock door handles and windows to work? How much weight can be saved by going from 1974 to earlier doors?
Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
Bontempi probably has some.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Have a couple of sets....you lose the impact bar only....don't know what it weighs.
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
On my DOT approved, highly precise bathroom scales:
Stripped early door (nothing, nothing and nothing) - 25 lbs Complete late door (glass, inside panel, wing window, latches, etc) - 60 lbs Don't early doors have different window mechanisms? |
SLITS |
Yep There are some early doors (late 72...Mid '73?) that have the late winder hardware but no impact bar, hence "lightweight racer" doors. |
olav |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None ![]() |
I think a early door is 20lbs about and a late door is about 60lbs. I picked both up to gauge them. Quite a difference indeed. |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
There is not that much differance in early vs late doors. I think this is a 914 myth. An COMPLETE early door weighs 45 pounds. I've weighed them myself.
There is a lot of differance between a stock complete late door and and a window-less early door. This is the weight savings route to take. Or go with a f/g door skin. Paul |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
If you want to keep the glass and keep it as a street car then I'm guessing your talking about 8-10 pounds max difference.
the door beam is a simple folded piece of sheet metal that is tacked in as a bar. Probably only weights 3 lbs for the bar itself. Still probably worth the switch for an autox car or something... The real weight savings is in removing the glass. I got my metal doors to 17lbs with working outside door handles (and modified inside ones) brant |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
gut them and reskin them in AL or FG (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Grant, I'm assuming you are keeping the glass is to stay in "FM", PCA class?
No glass moves you into "X" with the unlimited modifieds. In "X", anything goes. KT |
URY914 |
I'm in triple X. Now were talking "anything" (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Some call it a obsession, others call it a hobby. I call it a fetish. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) P |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
There is about a 20lb difference in the two doors. Early doors empty and late doors empty weight about 25 and 45 respectively.
Randal |
From the PCA rule book: Glass: The car must have full windows (glass or Plexiglas).
Windows don't have to be glass. |
URY914 |
I have both. I'll weigh them tonight. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Brett W |
And I the same.
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
exactly. although plexiglass would be crazy -- why do they write that? you want polycarbonate, obviously. |
Randal |
Available at TAP plastics |
URY914 |
Use Surane Wrap.
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
I was going to ask if anyone had seen those snap-on canvas doors?
Camel looks great, on a black, or green car. M |
URY914 |
Visqueen and duct tape.
Lo-Fi Version | Time is now: 26th June 2024 - 01:43 AM |
