914/6 rear brake seal kits? |
Tdskip |
Sep 20 2021, 06:45 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Good morning - considering having a go at rebuilding these myself but can't seem to find a kit with the seals etc. I know Eric and crew will do a great job rebuilding these but does anyone have a source for the kit if I decide to do them myself?
Thanks! |
mepstein |
Sep 20 2021, 08:02 AM
914-6 GT in waiting Group: Members Posts: 19,332 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Wouldn’t it be a rear M caliper kit with a couple 914-4 parts.
Tdskip |
Sep 20 2021, 09:26 AM
Good morning - are those the same piston size as the 914/6 rears? Aren't the 914/6 rear pistons bigger?
Clever idea if that works however. BTW - I should get the Carrera back with the 3.0 engine installed I bought from you today. Man, it sounds mean and rev's quickly. |
dr914@autoatlanta.com |
Sep 20 2021, 10:25 AM
914 Guru Group: Members Posts: 7,911 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes plenty, use a rear 911 caliper kit then add the four special o rings we make and be on your way
Good morning - considering having a go at rebuilding these myself but can't seem to find a kit with the seals etc. I know Eric and crew will do a great job rebuilding these but does anyone have a source for the kit if I decide to do them myself? Thanks! |
mepstein |
Sep 20 2021, 10:29 AM
Good morning - are those the same piston size as the 914/6 rears? Aren't the 914/6 rear pistons bigger? Clever idea if that works however. BTW - I should get the Carrera back with the 3.0 engine installed I bought from you today. Man, it sounds mean and rev's quickly. 914-6 calipers are M rear calipers with a 914 parking brake. The pistons are the same on both calipers. The Carrera engine is really special. It really is similar to a 2.7 RS with an aluminum case. I purchased another one a couple weeks ago from a Pelican seller. It's more of a long block kit that still needs parts and finishing. It also has a made up serial number. Fred Apgar assured me it was common on imported replacement engines to stamp a number. He once told me his shop built over 2000 engines so I believe what he says. Peter Dawe said the same and he has about 3000 engines to his name. |
Eric_Shea |
Sep 20 2021, 11:50 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
We have 914-6 rear caliper kits in stock. Complete with the adjuster seals, caliper 1/2 seals and the impossible to find welch plug. (IMG:style_emoticons/default/wink.gif)
Tdskip |
Sep 20 2021, 02:01 PM
Thanks for the discussion and info, very much appreciated.
Eric - will drop you a line as I have some other calipers for you anyway. Thanks! |
PatMc |
Sep 20 2021, 08:06 PM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
We have 914-6 rear caliper kits in stock. Complete with the adjuster seals, caliper 1/2 seals and the impossible to find welch plug. (IMG:style_emoticons/default/wink.gif) The Welch plugs aren’t that impossible to find…but the outer caps are… (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:29 PM |
