bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Removing the alternator for a possible overhaul or replacement and this just fell out of the passenger side motor. I've never seen this. It's a push in plug of sorts, hollow with a push down cap. ?? dime is for perspective.
And I don't trust any lift...Quickjack, 2 Almost safe jackstands, and the wheel under the tranny (IMG:style_emoticons/default/biggrin.gif) Poor pictures. Give me a few and I'll get better ones. ![]() Attached image(s) ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Looks like a mangled engine list bump stop.
Clay |
bandjoey |
(IMG:style_emoticons/default/biggrin.gif) Should have known. It keeps the passenger side from tilting more than the drivers side.
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
We can see the story now in the news…hydraulic jack leaks down and fails, putting weight on the ratchet jack stand which disengages then the entire rear end of the car rolls/swings unpredictably to one side or the other on the tire crushing what ever it call on and resulting in damaged body panels, brake rotors and who knows what else. Do your yourself a favor and get some real jackstands within safety pins, double them up for redundancy if you like.
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,884 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
We can see the story now in the news…hydraulic jack leaks down and fails, putting weight on the ratchet jack stand which disengages then the entire rear end of the car rolls/swings unpredictably to one side or the other on the tire crushing what ever it call on and resulting in damaged body panels, brake rotors and who knows what else. Do your yourself a favor and get some real jackstands within safety pins, double them up for redundancy if you like. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
bandjoey |
Using quick Jack. After lifting it rests on to steel to steel safeties but I like your tv disaster scenario (IMG:style_emoticons/default/biggrin.gif) Quick Jack allows vehicle lifted indefinitely as long as the locks are in place.
Lo-Fi Version | Time is now: 26th June 2024 - 01:25 PM |
