fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,103 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
I was disassembling/scrapping some old computer equipment and separating the metal frames from the electronics. Came across an assembly that was riveted together rather than screws. Drilled out some and got to wondering how they do it.
Second picture is the inside bracket of the first picture. ![]() ![]() |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,478 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Looks like what they use on disc / drum pads and shoes. It is a machine
Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,038 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,440 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
+1, look like the pop rivets I can do with my cheap gun
fixer34 |
+1, look like the pop rivets I can do with my cheap gun That's what I thought too, but the pop-rivets I've used leave a small metal head either in the rivet, or they fall out inside. This is a housing for an electronics circuit board and is closed up when fully assembled/riveted. There are probably 20 rivets on this piece alone. They can't take a chance of a head bouncing around inside so there has to be another way to do it. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,439 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:58 PM |
