Idle problems, I know you know!!! |
BahnBrenner914 |
Jul 27 2005, 10:00 PM
The girl is gone and all I have now is a beat-up teener Group: Members Posts: 301 Joined: 22-May 04 From: Gig Harbor and University Place, WA :: School in Angola, IN :: girlfriend in Sarasota, FL Member No.: 2,094 Region Association: None |
So the ongoing project has been restarted after a 3 month break... no comment... and i fired the car up again and it starts and runs and isnt hunting much... the problem is that it idles at 1500 when i fire it up and then it slowly (really SLOWLY, like 30 seconds) climbs up to 2000 and i dont know if it will climb higher (i'll post a comment when i let it run longer tonight). I know 99% of you all have dealt with this, so help me go from (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) to (IMG:http://www.914world.com/bbs2/html/emoticons/driving-girl.gif)
Bleyseng |
Jul 27 2005, 11:10 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
check to make sure the vacuum hoses are connected correctly and check for vacuum leaks.
If the AAR valve is working it will start out with a 1500-1800 idle then after 5 minutes drop down to whatever you idle is set to. To check to vacuum leaks plug the AAR valve hose so it can't leak and then you can look for other leaks. |
Rand |
Jul 27 2005, 11:49 PM
Mine also idles faster after warmed up, and it's been a hair-pulling battle.
If the AAR valve is NOT working, it should fail closed, right? Meaning opposite behavior of what we are experiencing... It should open when cold, then close down as it warms up. It should feed extra air into the intake when it's cold, and therefor idle faster when cold and slow down as it warms up. So a bad AAR would mean when cold it might idle slower or need some gas pedal feathering until it warms up, but not idle faster when warm. Fast idle usually means vacuum leak (or improperly connected vacuum hoses) or too-advanced timing. But I still haven't figured out how temperature plays into this yet, especially when it idles faster after warm. |
Dave_Darling |
Jul 28 2005, 12:39 AM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The AAR typically fails open, though I have heard people say that theirs failed closed. The valve sits open most of the time (because we can only drive the car so many hours per day, right?). So when it freezes up, it tends to freeze open.
That could cause this sort of behavior. --DD |
Rand |
Jul 28 2005, 12:52 AM
Ok, good to know. But in my particular case, the behavior didn't change if I plugged the hose after the AAR valve. So I know I'm not getting faster idle after warm because of the AAR valve staying open. Still searching...
Bleyseng |
Jul 28 2005, 07:28 AM
I vote this is the number one complaint, bad idle.
Usually the AAR is rusted stuck open, the idle is adjusted wrong and there are vacuum leaks. Its like chasing your tail! Test the AAR to see if it opens and closes first. Then check the hoses to see if they are connected properly. Then test for vacuum leaks ie injector seals, hoses, TB gasket, worn out dizzy etc... |
BahnBrenner914 |
Jul 28 2005, 12:28 PM
yeah, i started it up last night and it started running about 1500 to 2000 but after a minute and some revving, it calmed down to a 1100 idle. I also noticed that when i revved it, it went up quick and then came back down really slow. I've replaced all the vacuum hoses so i know they are all good... and where is this AAR valve?
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
Bleyseng |
Jul 28 2005, 02:20 PM
see pic
Attached image(s) |
smooth_eddy |
Jul 28 2005, 04:30 PM
Senior Member Group: Members Posts: 535 Joined: 13-November 04 From: Seattle Member No.: 3,102 |
The AAR is easy to remove and bench test with aligators and a battery charger. I had similar problems, 20 minute Geoff found incorrectly connected vac hoses and a bad AAR on my car. Eddy
redshift |
Jul 28 2005, 04:36 PM
Nice pic, Geoff! Where'd you get that one? I don't think I've see it before... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) M |
Bleyseng |
Jul 28 2005, 04:48 PM
here is how Miles fixes his AAR valve...by doing the AAR Valve Dance!
Attached thumbnail(s) |
Dave_Darling |
Jul 28 2005, 05:52 PM
Also check the Decel Valve. It could be sticking open.
--DD |
DNHunt |
Jul 28 2005, 06:31 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Damn Miles that's one tall sheep.
fatlando |
Jul 28 2005, 07:49 PM
Member Group: Members Posts: 259 Joined: 6-September 04 From: imperial beach, california Member No.: 2,700 |
my car is doing the same up and down thing too. I have a fuel injected stock 75 2.0 engine. that photo that was pictured, can i use that as a refrence?
thanx fat lando |
BahnBrenner914 |
Jul 28 2005, 09:06 PM
Where is that? i dont see it in the wonderfully labeled pic |
Rand |
Jul 28 2005, 10:44 PM
On my '75 2.0 it was right next to the MPS. Fastened by the same clamp in fact. Now it's gone.
Spilled Spot remover on my dog. Now he's gone. I digress. |
Bleyseng |
Jul 28 2005, 10:58 PM
The MPS and decel valve are mounted under the battery tray. Chuck the decel valve and plug the hoses....
Use the 73 2.0l pic for hose layout as its a real Factory pic! |
Dave_Darling |
Jul 29 2005, 10:30 AM
A real factory pic, with only a few things moved around and in the wrong place....
--DD |
fatlando |
Jul 29 2005, 12:44 PM
Dave, Do you have the whereabouts of a "real" factory picture of all the vaccum hoses for a stock fuel injected 75 2.0? i gotta fix my kerplunk this weekend. |
Dave_Darling |
Jul 29 2005, 01:03 PM
Nope!
I do, however, know where there are some line-drawings (which can occasionally show things clearer than photos) that have the 73-74 2.0 hose locations. The fuel hose routing is slightly different on the 75-76 cars, of course... You could use the 75 1.8 diagram for the fuel hose routing, I suppose. --DD |
Lo-Fi Version | Time is now: 26th December 2024 - 09:26 PM |
