Rusted Heat Control Box Clean Up, Final Results Pics Added |
914Sixer |
Nov 13 2021, 04:30 PM
914 Guru Group: Members Posts: 9,032 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will need a bucket, gallon of white vinegar and quart of lemon juice. Depending on the bucket size, mix 2 parts vinegar to 1 part lemon juice. Soak part along as needed. Pull part from time to time and scrub with small tooth brush size wire brush. Keep repeating until you are satisfied clean enough to paint. Wash, dry and get ready to apply paint as flash rust will appear as soon as the part is dry. Took about 6 hrs to soak and come clean. Going to finish off with wire wheel. Before and after, you can see flash rust .
Attached image(s) |
930cabman |
Nov 13 2021, 04:35 PM
Advanced Member Group: Members Posts: 3,775 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Looks good as new, what will you be using for a primer?
BeatNavy |
Nov 13 2021, 04:36 PM
Certified Professional Scapegoat Group: Members Posts: 2,944 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Nice, Mark. I have a collection of those that could use this treatment. Some that work better than others (IMG:style_emoticons/default/dry.gif)
914werke |
Nov 13 2021, 04:41 PM
"I got blisters on me fingers" Group: Members Posts: 11,022 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/aktion035.gif)
Although I think you are making it more difficult than needed (IMG:style_emoticons/default/smile.gif) Apple cider vinegar (min 5% acidity) toss um in undiluted for a day or two. Pull out & rinse using a brush to remove rust sediment (will come right off). Dunk in a bath of water & baking soda to neutralize I go to the added step and blast them & powder coat the outsides otherwise theyll rust in no time. (IMG:style_emoticons/default/happy11.gif) |
930cabman |
Nov 13 2021, 05:38 PM
Or, just drop them in a blast cabinet?
914Sixer |
Nov 13 2021, 06:18 PM
Going to use high temp primer and paint. Blast cabinet method is ok if you are going to powder coat because paint needs rough surface to adhere. Did not have loads of time in job, let the bucket solution do the work. Maybe 5 min in clean up each brushing.
bandjoey |
Nov 13 2021, 10:31 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Memory is old but think there's a cork gasket on that and it seems like 914rubber had those at one time. miscellaneous thought
Geezer914 |
Nov 14 2021, 07:22 AM
Geezer914 Group: Members Posts: 1,790 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
The best rust remover I have used is Krud Kutter The Must For Rust. Soak parts overnight. It removes rust and paint and etches the metal for paint.
914Sixer |
Nov 14 2021, 01:01 PM
Final result
Attached image(s) |
mlindner |
Nov 14 2021, 01:07 PM
Senior Member Group: Members Posts: 1,590 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Very nice Mark, thanks for sharing. Mark
bdstone914 |
Nov 14 2021, 02:01 PM
bdstone914 Group: Members Posts: 4,731 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
If you want to speed up the process hameat the vinegar to near boiling. Smelly but works fast.
bkrantz |
Nov 14 2021, 09:13 PM
914 Guru Group: Members Posts: 8,173 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I REALLY like Evaporust. Works extremely well with overnight soaking, and seems to be very safe for any plastic bits that can't be detached. But it will remove paint (for good or bad).
https://www.evapo-rust.com/evapo-rust/ |
Root_Werks |
Nov 16 2021, 01:47 PM
Village Idiot Group: Members Posts: 8,505 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Turned out nice!
Lo-Fi Version | Time is now: 22nd December 2024 - 06:28 AM |
