914 with ej205 wiring question |
jeepguy06 |
Dec 8 2021, 01:37 PM
Newbie Group: Members Posts: 45 Joined: 11-January 21 From: portland or Member No.: 25,060 Region Association: Pacific Northwest |
so i have been building my 914 and got to the motor and ecu part. i have cut the wiring harness from 2002 impreza wrx full harness but the problem i am having now is that the obd2 port wont read. I have been able to use a bluetooth reader to pull codes. when i plug in a cable reader i get an error and the tactrix 2.0 cable using ecuflash wont do anything. just keeps telling me failed . i have looked at the wiring diagrams and all the wires are in the pin locations they call for but there are two wires not hooked up. green red and brown white. they go to the abs brain. can someone shed some light on what might be going on or how most of you wired yours in to work. (IMG:style_emoticons/default/headbang.gif)
tazz9924 |
Dec 8 2021, 07:09 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
so i have been building my 914 and got to the motor and ecu part. i have cut the wiring harness from 2002 impreza wrx full harness but the problem i am having now is that the obd2 port wont read. I have been able to use a bluetooth reader to pull codes. when i plug in a cable reader i get an error and the tactrix 2.0 cable using ecuflash wont do anything. just keeps telling me failed . i have looked at the wiring diagrams and all the wires are in the pin locations they call for but there are two wires not hooked up. green red and brown white. they go to the abs brain. can someone shed some light on what might be going on or how most of you wired yours in to work. (IMG:style_emoticons/default/headbang.gif) Big thing make sure you have power and ground at the port. i forget which pins but it’s universal |
jeepguy06 |
Dec 8 2021, 07:31 PM
so i have been building my 914 and got to the motor and ecu part. i have cut the wiring harness from 2002 impreza wrx full harness but the problem i am having now is that the obd2 port wont read. I have been able to use a bluetooth reader to pull codes. when i plug in a cable reader i get an error and the tactrix 2.0 cable using ecuflash wont do anything. just keeps telling me failed . i have looked at the wiring diagrams and all the wires are in the pin locations they call for but there are two wires not hooked up. green red and brown white. they go to the abs brain. can someone shed some light on what might be going on or how most of you wired yours in to work. (IMG:style_emoticons/default/headbang.gif) Big thing make sure you have power and ground at the port. i forget which pins but it’s universal I have checked and yes I have power and grounds. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:49 AM |
