nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Requesting some good pics of the fuel pump mounted under the steering components. I have found several, but none are looking at it directly. Does someone have some they can post? Measurements can help too, slight OCD lol. Looking to remount mine on my 74 and want to get the location correct.
@iankarr I was looking through your vid logs, but didn't see any for when you relocated yours in your BB. Thanks all! |
iankarr |
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,484 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region ![]() ![]() |
I shot the process, but not edited yet. Coming soon!
nditiz1 |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,835 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
iankarr |
Jamie |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,038 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States ![]() ![]() |
Quick frame grab. This was in-process. The hoses and wires are properly routed now. The angle makes it look like the pump hits the steering bellows, but it doesn't... ![]() I eliminated all the possible kinks in the fuel line loops by forming U's from metal fuel line. Was easy to construct and eliminated potential future rubber line aging and collapse. Added filter between tank and pump to eliminate troublesome sock in tank, and another filter after pump to tunnel line, and they are readily serviceable in this location without need to remove tank. |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
I have a couple of mine under the fuel tank, more room and less road debris that way.
Happy to lend a hand if helpful. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:58 AM |
