2 Black wires on the + side of the coil. |
Geezer914 |
Feb 12 2022, 02:30 PM
Geezer914 Group: Members Posts: 1,660 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
There are 2 black wires joined together coming off the + side of the coil. One goes to the ignition switch, where does the other one connect to?
914sgofast2 |
Feb 12 2022, 04:38 PM
Senior Member Group: Members Posts: 645 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Geezer914 |
Feb 12 2022, 05:33 PM
I am installing a Pertronix digital HP box. They are showing the wire from the ignition switch going to the red wire on my Mallory distributor. The 2 wires black wires are attached together. Just want to be sure one doesn't t stay on the + side of the coil.
JeffBowlsby |
Feb 12 2022, 07:05 PM
914 Wiring Harnesses Group: Members Posts: 8,663 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I am installing a Pertronix digital HP box. They are showing the wire from the ignition switch going to the red wire on my Mallory distributor. The 2 wires black wires are attached together. Just want to be sure one doesn't t stay on the + side of the coil. Do have L-jet? |
Geezer914 |
Feb 12 2022, 08:49 PM
Yes, Ljet. Installing a Pertronix Digital HP box to a Mallory Unilite distributor Wire diagram shows taking the wire from the ignition switch and the red wire from the box, and connecting it to the red wire on the distributor. Should I separate the 2 wires connected to the coil+, taking the black/red wire going to pin 7 (12 pin connector) and leave it connected to the coil+, and connect the black wire to the distributor?
Lo-Fi Version | Time is now: 27th September 2024 - 10:13 AM |
