krazykonrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 ![]() |
It looks like I have a seized valve guide. Any recommendations on valve spring compressors?
Thanks (IMG:style_emoticons/default/beerchug.gif) Konrad |
914Mels |
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California ![]() |
Till you figure out what compressor you want you can take the springs off with a rag stuffed in the combustion chamber (heads off obviously) and a appropriate size socket for the valve spring retainer and a hammer. Wack the retainer with the hammer and the keepers should pop out and stay in the socket.
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Take it to a machine shop, make it simple on yourself.
roblav1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region ![]() |
I've been able to make a crappy NAPA one work for years. Patience.
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,212 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
Factory tool works good but is hard to find.
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
A tool similar to the factory tool is being sold by someone on the Samba website. The Bay Window buses used heads similar to the 914’s; and even the same in some instances.
Lo-Fi Version | Time is now: 25th June 2024 - 09:09 PM |
