Robarabian |
914 A Roo ![]() ![]() ![]() Group: Members Posts: 593 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California ![]() ![]() |
Hi all,
Bruce Stone was nice enough to soruce me a nicer than I had driver side window for my 72. The attached photo shows the piece in question I need help with. I need to remove the metal piece that is glued to the bottom of the glass, to transfer it to the glass Bruce got me. It is on there pretty good. I'm trying not to break the glass, as someone surely could use it or it could remain a spare, since they are rare. I tried using a heat gun, but im afraid to go to hot and break the glass. Prying is futile. I have worked a razor blade as far in as I can. Also, is it glued in with window butyl in a tube type stuff? Anyone have a secret? ![]() |
barnfind9141972 |
Member ![]() ![]() Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California ![]() |
Hi all, Bruce Stone was nice enough to soruce me a nicer than I had driver side window for my 72. The attached photo shows the piece in question I need help with. I need to remove the metal piece that is glued to the bottom of the glass, to transfer it to the glass Bruce got me. It is on there pretty good. I'm trying not to break the glass, as someone surely could use it or it could remain a spare, since they are rare. I tried using a heat gun, but im afraid to go to hot and break the glass. Prying is futile. I have worked a razor blade as far in as I can. Also, is it glued in with window butyl in a tube type stuff? Anyone have a secret? ![]() @robarabian patience is key, just went through the same thing. Fishing wire worked for me, just work it little by little. Switch to a razor blade and cut any adhesive as you go. You can try soaking it in solvents need be and see if that eats away at any butyl or glue. Good luck (IMG:style_emoticons/default/beerchug.gif) |
Robarabian |
I hope my kids don't miss the piano lessons.. Ill see what I have wire wise...thats a good tip. Thank you.
Lo-Fi Version | Time is now: 25th June 2024 - 12:21 AM |
