RandyE |
Newbie ![]() Group: Members Posts: 13 Joined: 5-March 22 From: california Member No.: 26,373 Region Association: None ![]() |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Small hole was for brake fluid over flow line on 70-71 cars, not used on later years. Others are drain/vent holes.
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
Small hole was for brake fluid over flow line on 70-71 cars, not used on later years. Others are drain/vent holes. Yes sir Mark two small holes for brake fluid line is at the driver side and those holes on the picture I think one for water drain from the fresh air box and the other hole for the fuel filler neck drain. Big hole is an access hole from the bottom. |
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
By the way, the picture looks like you still have the original fuel lines -- the first foot (ish) of each is steel and the rest is vinyl tubing. If that's the case, you should really consider replacing all the fuel lines with new steel or stainless steel tubing. The vinyl gets old and brittle over time, and too many 914s have been lost to fuel fires from broken lines.
There are several vendors on this site that sell nice stainless lines. |
RandyE |
By the way, the picture looks like you still have the original fuel lines -- the first foot (ish) of each is steel and the rest is vinyl tubing. If that's the case, you should really consider replacing all the fuel lines with new steel or stainless steel tubing. The vinyl gets old and brittle over time, and too many 914s have been lost to fuel fires from broken lines. There are several vendors on this site that sell nice stainless lines. Thank you for letting me know about that, Bill! This is my first 914 and air cooled vehicle. It has sat for many years so i am trying to get it running on a budget to make sure it is worth it first before dropping too much money! |
RandyE |
Small hole was for brake fluid over flow line on 70-71 cars, not used on later years. Others are drain/vent holes. Thank you for the info. Sorry, i should have mentioned mine is a 72 (Jan 72 on door sticker). So it is customary to leave those holes as is (not plugged) i am assuming? Thanks again! |
RandyE |
Small hole was for brake fluid over flow line on 70-71 cars, not used on later years. Others are drain/vent holes. Yes sir Mark two small holes for brake fluid line is at the driver side and those holes on the picture I think one for water drain from the fresh air box and the other hole for the fuel filler neck drain. Big hole is an access hole from the bottom. Thank you for your feedback! I appreciate it! |
Lo-Fi Version | Time is now: 25th June 2024 - 09:02 PM |
