bossboy302 |
Member ![]() ![]() Group: Members Posts: 77 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None ![]() |
1972 914. Found numbers "2749551" stamped in the lower right rear corner of the rear trunk floor. Do not match the VIN. What do they mean? Car been knotted together? Production #?
(IMG:http:///Users/brianferrin/Pictures/Photos%20Library.photoslibrary/resources/proxies/derivatives/0a/00/a84/UNADJUSTEDNONRAW_thumb_a84.jpg) |
tygaboy |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,332 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California ![]() ![]() |
That's the chassis #, not going to match the VIN. Someone more expert than I will chime in but you can figure out date of mfg from that. So long as it's "in range" to the VIN production info and there's nothing else to indicate your car's been clipped, you're probably fine.
And I'm speaking from experience. I had a car that had an impossible chassis #: the vin was from '73, the chassis # from '74, and far enough apart to indicate the car was clipped. |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,490 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Check the drivers door frame plate below the A pillar. And also I believe you'd find that number on the passenger side light bucket, there is a plate viewable opening the frunk.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
What do they mean? www.914world.com/bbs2/sources/action_public/pop_helpchassis.html ![]() (IMG:style_emoticons/default/shades.gif) |
bossboy302 |
Many thanks.
Confirmed the numbers in question with door plate and under dash scribble. Same. Slight sigh... |
Lo-Fi Version | Time is now: 25th June 2024 - 11:52 PM |
