> Degreasing a wire harness?
Geezer914
post Mar 15 2022, 12:12 PM
Geezer914
What is the best way to degrease a fuel injection wire harness? (IMG:style_emoticons/default/popcorn[1].gif)
JeffBowlsby
post Mar 15 2022, 12:47 PM
914 Wiring Harnesses
QUOTE(Geezer914 @ Mar 15 2022, 11:12 AM) *
paint thinner
acetone
Geezer914
post Mar 15 2022, 02:21 PM
Geezer914
Thanks for the reply
troth
post Mar 15 2022, 02:34 PM
I’d try naptha first if you have it handy. A little less harsh than acetone, and very effective for removing glue residue eg melted electrical tape
brant
post Mar 15 2022, 03:18 PM
I recently cleaned one with simple green and a hundred rags
Root_Werks
post Mar 15 2022, 03:54 PM
Village Idiot
QUOTE(brant @ Mar 15 2022, 02:18 PM) *
Been going through this for the last few days.
At first I was "This stuff smells kinda nice".
15 minutes later I was ready to barf my dinner. (IMG:style_emoticons/default/icon8.gif)
Dunno what it is about Simple Green, starts off pleasant and turns overpowering.
930cabman
post Mar 15 2022, 04:20 PM
Try Dawn dish washing soap, it will rinse easily with water and easy on things, your body included.
Geezer914
post Mar 15 2022, 05:09 PM
Geezer914
Trying to avoid using anything water soluble that will seep into the wiring causing corrosion.
vitamin914
post Mar 15 2022, 06:02 PM
I use 3M electrical contact cleaner. Basically a citrus based chemical solvent. Not a bad smell. Not water based.
I agree regular Simple Green reeks, but they make a clear uncolored unscented version called Crystal (available at Uline). The Crystal Simple Green smells like the soak spray at DIY car washes. Chemical smell yes but not revolting like the Green coloured stuff.
I use it in the engine bay of cars.
windforfun
post Mar 15 2022, 07:09 PM
QUOTE(JeffBowlsby @ Mar 15 2022, 10:47 AM) *
paint thinner
acetone
These solvents will melt what you're trying to clean. Try WD-40.
ndfrigi
post Mar 15 2022, 07:58 PM
Is that the harness I bought? yehey! I don’t need to clean them anymore.
bkrantz
post Mar 15 2022, 09:07 PM
I used Goof Off, since I had to remove both grease and #$%^*&^ PO undercoating spray. That meant separating all the wires for cleaning access, and then re-taping the harness.
In my experience, Goof Off is a strong solvent that is safe on most paint and other finishes--just watch it on some plastics.
Krieger
post Mar 15 2022, 10:10 PM
How about gasoline? As long as the harness is not in the car and your outside. Use an oil drain pain and a cheap paint brush
JeffBowlsby
post Mar 15 2022, 10:28 PM
[quote name='windforfun' date='Mar 15 2022, 06:09 PM' post='2988496']
[quote name='JeffBowlsby' post='2988370' date='Mar 15 2022, 10:47 AM']
[quote name='Geezer914' post='2988360' date='Mar 15 2022, 11:12 AM']
[quote]
paint thinner
acetone
[/quote]
[/quote]
I regularly use citrus degreasers, simple green, paint thinner, acetone depedning on the situation, and have for at least 20 years to clean up harnesses. Acetone will remove the color striping and printed numbering on wire insulation so be cautious. No harness damage whatsoever. The military uses acetone for this exact purpose, but the caution is to wear latex gloves and work in a well ventilated area. The solvents work the best against grease residues, the water based degreasers less so, but all are effective with enough effort. There may be other cleaners that could be effective but I have not tried everything. Harness casing is chemical resistant and quite durable.
brant
post Mar 16 2022, 06:43 AM
QUOTE(ndfrigi @ Mar 15 2022, 07:58 PM) *
Yes sir
I stretched it out on the floor and spent a few hours cleaning it
It was the best way to examine all of the terminals and condition
ndfrigi
post Mar 16 2022, 09:54 AM
QUOTE(brant @ Mar 16 2022, 05:43 AM) *
Yes sir
Nice and thank you again sir!
Now just need to open the box from shipping and test all the connections!
Tbrown4x4
post Mar 16 2022, 10:03 AM
This is a timely topic. I thought somebody here had recommended waterless hand cleaner. The gel type without the pumice.
I haven't tried it yet, but it certainly seems like everybody has their favorite!
post Mar 16 2022, 10:18 AM
914-6 GT in waiting
You would be amazed at what magic erasers can do. I just wiped all the brake dust off these calipers with a magic eraser and water. No solvents. Best thing was I could do it in the house and my wife didn’t complain about any smell.
If my wife is ever going to divorce me, it will be because I made the house smell bad with a solvent. She is very sensitive to that.
Geezer914
post Mar 16 2022, 06:21 PM
Geezer914
I just cleaned the harness by placing it in an oversized Ziploc bag and adding 1/3 can of paint thinner. I dumped it out and repeated the process. I then cleaned everything with a parts brush. Rinsed again with paint thinner. Wiped off the excess with paper towels, then sprayed the harness and plugs with CRC contact cleaner and left it outside to dry.
- Lo-Fi Version Time is now: 26th December 2024 - 06:41 PM
