Fuse panel findings, Is this normal? |
robkammer |
Mar 18 2022, 12:49 PM
Member Group: Members Posts: 200 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: North East States |
Hi Teeners. For those of you who have seen everything 914 related, please have a look at the hack connection I found on the back of my fuse panel. I'm assuming this is the hazard relay? Why would it have needed a half assed jumper like this? My flashers do not work by the way, but I believe everything else does. I feel like I'm jumping into a rat hole here.
I also found another hack attached to the #8 fuse that ran to the non functioning A/C, I pulled that off the board. Any and all input is appreciated, not judged! Thanks |
ClayPerrine |
Mar 18 2022, 12:54 PM
Life's been good to me so far..... Group: Admin Posts: 15,948 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Hi Teeners. For those of you who have seen everything 914 related, please have a look at the hack connection I found on the back of my fuse panel. I'm assuming this is the hazard relay? Why would it have needed a half assed jumper like this? My flashers do not work by the way, but I believe everything else does. I feel like I'm jumping into a rat hole here. I also found another hack attached to the #8 fuse that ran to the non functioning A/C, I pulled that off the board. Any and all input is appreciated, not judged! Thanks That is actually the high/low beam relay. The hack is probably to make it work with the replacement relay that has an extra pin. And it is a crap hack..... There is a thread somewhere on here that will tell you how to fix it right. Clay |
mepstein |
Mar 18 2022, 12:55 PM
914-6 GT in waiting Group: Members Posts: 19,642 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Better to deal with it now than some night far from home.
Superhawk996 |
Mar 18 2022, 01:12 PM
914 Guru Group: Members Posts: 6,590 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Better to deal with it now than some night far from home. What a fine (IMG:style_emoticons/default/stromberg.gif) show that "hack" is. I can't fathom what people are thinking with a "fix" like that. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/lol-2.gif) Remembering @Bbrock scenario -- (IMG:style_emoticons/default/yikes.gif) mountain curve no lights |
robkammer |
Mar 19 2022, 02:15 PM
Thanks fellas. Maybe that explains why the fog lights turn on when the high beams should, and the reverse happens when the fog lights should light. I would like to bring it back to original if possible. Is an original style relay still available? If anyone has a link to that fix please share. I find it pretty difficult to search the forum. Sir Andy had a hack a while back that messed it up I think.
Rob |
Superhawk996 |
Mar 19 2022, 03:23 PM
I find it pretty difficult to search the forum. Sir Andy had a hack a while back that messed it up I think. Rob Use Google. Format -- to search for relay board site:914world.com relay board I've got to admit though, it seems to me, this doesn't work as well as it used to. Google probably doing something with its algo? |
FlacaProductions |
Mar 19 2022, 05:03 PM
Senior Member Group: Members Posts: 1,840 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I've used that google search formatting for a long time but it doesn't seem to work like it used to....
Superhawk996 |
Mar 19 2022, 05:41 PM
I've used that google search formatting for a long time but it doesn't seem to work like it used to.... Glad it's not just me . . . . . Google fact checkers not able to keep up with 914world.com in order to make sure we don't get relay board misinformation. (IMG:style_emoticons/default/av-943.gif) |
robkammer |
Mar 20 2022, 08:48 AM
Found the thread, should have looked at Georges tips book first. It's a jumper to convert the new style 5 pin relay to to replace the NLA 4 pin version. The proper hack is to jumper it to the incoming power lug with the red/white wire. This guy just took it to the panel instead. I'm going to try to find a four pin.
1 down, plenty left to resolve. |
Lo-Fi Version | Time is now: 22nd December 2024 - 05:53 AM |
