DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,769 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
I have one of Ben's beautiful mufflers on my car, and i just pulled it out along with the transmission, and noticed it is rubbing on the left back side , small spot on the very far left side, rear where the stock heat shield curves down at the back edge. I was thinking that it has partly to do with Ben's muffler being straight so it gets closer out to the outside on both sides but only rubs on left. Can i put some spacers at the rear transmission mount to drop the rear abut 1/4"? If so, what to use? I have the 911 engine mounts for the transmission mounts with stock hardware and bolts and washers. OR option 2 try and bend that shield but those welded brackets hold it really tight. OR Remove the shield completely and place heat shield material on bottom side of the trunk floor for defection of the heat. any other thoughts please they would be greatly appreciated. Phil |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
If you take the muffler bracket off of the trans does it lower it enough to stop the rubbing? If so elongate the holes on the muffler bracket to lower it.
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Show a picture of your trans mount assembly on the car.
IIRC, the stackup is different with them than with stock mounts. It may be easiest/best to lower the trans by adding spacers on the big bolts between the trans and the mounts. |
Steve |
The only issue I had with 911 mounts, is that I had to elongate the holes. Are the 911 mounts installed correctly?
DRPHIL914 |
If you take the muffler bracket off of the trans does it lower it enough to stop the rubbing? If so elongate the holes on the muffler bracket to lower it. Show a picture of your trans mount assembly on the car. IIRC, the stackup is different with them than with stock mounts. It may be easiest/best to lower the trans by adding spacers on the big bolts between the trans and the mounts. i will take a picture when i get home. I was thinking that too that a washer at the top of the transmission ear would lower it a tad, i may have to get longer bolts, there is only about a quarter inch sticking out the bottom . on the issue of the bracket if you do that you are letting it sag a bit and then isnt that putting stress on the HE mount ears a bit? Phil |
Steve |
If you take the muffler bracket off of the trans does it lower it enough to stop the rubbing? If so elongate the holes on the muffler bracket to lower it. Show a picture of your trans mount assembly on the car. IIRC, the stackup is different with them than with stock mounts. It may be easiest/best to lower the trans by adding spacers on the big bolts between the trans and the mounts. on the issue of the bracket if you do that you are letting it sag a bit and then isnt that putting stress on the HE mount ears a bit? Phil I agree, you don’t want to force it down, but letting it hang and then lifting it up a bit to take the weight off might clear the heat shield. Also take a close look at the heat shield. Is it bent or possibly a broken weld. Sometimes they get banged up with installing and removing a rear sway bar. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,979 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
The 1.7 and 1.8 mufflers were very very close to the heat shield and the shield bends slightly downward at the ends. If the muffler were a banana it would fit better.
ChrisFoley |
Steve |
The only issue I had with 911 mounts, is that I had to elongate the holes. Are the 911 mounts installed correctly? ![]() ![]() For one thing, your cups are upside down. They need to be flipped. and yes, the small holes need to be elongated to fit the 914. Chris, Good eye. Those are pictures I found on google, not from the OP. Never trust the Internet!! Sorry about that!! |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,683 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
I have one of Ben's beautiful mufflers on my car, and i just pulled it out along with the transmission, and noticed it is rubbing on the left back side , small spot on the very far left side, rear where the stock heat shield curves down at the back edge. Can i put some spacers at the rear transmission mount to drop the rear abut 1/4"? If so, what to use? I have the 911 engine mounts for the transmission mounts with stock hardware and bolts and washers. Put 1/4" spacers above the trans mounts to move my muffler down a little as the exhaust pipes were hitting on my rear valence. ![]() |
DRPHIL914 |
I have one of Ben's beautiful mufflers on my car, and i just pulled it out along with the transmission, and noticed it is rubbing on the left back side , small spot on the very far left side, rear where the stock heat shield curves down at the back edge. Can i put some spacers at the rear transmission mount to drop the rear abut 1/4"? If so, what to use? I have the 911 engine mounts for the transmission mounts with stock hardware and bolts and washers. Put 1/4" spacers above the trans mounts to move my muffler down a little as the exhaust pipes were hitting on my rear valence. ![]() that’s probably what i will do @ChrisFoley here is a pic of mine Attached thumbnail(s) ![]() |
ChrisFoley |
That works, but I would rather see a single spacer on the large bolt, between the cup and the mount.
DRPHIL914 |
That works, but I would rather see a single spacer on the large bolt, between the cup and the mount. @ChrisFoley That should be easy enough to do, but i may need longer bolts, as putting in a 1/4" spacer there will put the nut right at the end of the bolt. any ideas to pick up both of these before saturday?- oh and do you have any of the clutch pully adaptors in stock for the side mounting? Phil |
ChrisFoley |
We replaced those top pieces with large washers. They really don't fit against the 911 mount properly.
I don't think you'll need longer bolts. I can ship a pulley adapter this week. |
Lo-Fi Version | Time is now: 1st July 2024 - 05:19 AM |
