Sound proofing doors |
Geezer914 |
Mar 25 2022, 09:03 AM
Geezer914 Group: Members Posts: 1,805 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Is it worth the effort to install sound proof mat on the inside of the doors?
mepstein |
Mar 25 2022, 09:14 AM
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I believe so. It doesn't have to cover the entire area to be effective.
RJMII |
Mar 25 2022, 09:22 AM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
Is it worth the effort to install sound proof mat on the inside of the doors? the sound deadening material like kilmat, fatmat, noico, etc that's dense rubbery material absorbs a lot of vibration when applied correctly. it should be on the inside of the door skin, to be most effective. |
mlindner |
Mar 25 2022, 11:02 AM
Senior Member Group: Members Posts: 1,598 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
RJM, yes also and easy to do. Don't worry about the safety bar if you have later doors, just get in on the big flat areas and stay about a inch up from the bottom so all water drains out. Best, Mark
friethmiller |
Mar 25 2022, 11:54 AM
Senior Member Group: Members Posts: 711 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
mb911 |
Mar 25 2022, 04:39 PM
914 Guru Group: Members Posts: 7,386 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I used noico it really makes a difference.
vintagethunder |
Mar 25 2022, 05:33 PM
Newbie Group: Members Posts: 39 Joined: 7-January 22 From: Monmouth, IL Member No.: 26,225 Region Association: Upper MidWest |
My '71 has that spray on type undercoating inside the doors. Is that not the way it was delivered?
Tom |
Cairo94507 |
Mar 26 2022, 07:00 AM
Michael Group: Members Posts: 10,144 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Yes, they came with some spray-on undercoating on the inside fo the doors. But technology has come a long way- the stick-on sound deadening stuff is easy to apply and works great. Apply it to the inside of your doors as mentioned and you will be surprised how much quieter the car is. Also, when you shut the door you will hear the difference too. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 4th January 2025 - 07:12 PM |
