914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,915 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I had a couple of dead clocks and I wanted to bring them back to life. VDO Audi clocks are the same unit as the one used in the 914 center console clock. HOWEVER please be AWARE there are vast differences. You have to make sure you pick the clock that MATCHES the rear of the one you have. Some of the early 914 ones use the same as the 911 and Audi. Later 914 can ONLY use one version of the Audi clock. MOTORMETER version is NOT acceptable.
The procedure is really simple, finding the correct clock is the hard part. This procedure is for the late clock only. Take off the clock trim ring. Remove the 3 screws on the back. Unsolder the button, clock will drop out. Remove the hands of the clock and remove faceplate of 914 clock. Follow the same procedure removing the clock from the Audi case. Audi clock will have inner steel case that is not needed. Remove the hands and swap out the faceplate to 914. Replace new hands on clock. Now you are ready to put new movement back in 914 case. Align movement making sure you have the pin aligned for soldering. Hold movement and tighten 3 screws snug, remembering that are going into 50 year old PLASTIC. Take some solder wick and clean up old solder. Solder button. Power up clock and see IF it works. Movement MUST be grounded to case for it to work. There are 3 different versions of front winding stem. It is hard to know which one will work with the new clock 1 Motormeter clock that will not work 2 Rear of Audi clock that will work on late 914 clock 3 Replacement Audi Clock for Early 914 4 Replacement Audi clock for late 914 clock Early non quartz clock is a waste of time in my opinion. Attached thumbnail(s) ![]() ![]() ![]() Attached image(s) ![]() |
914Sixer |
Two clocks I did, plastic lens are terrible. Will send to NHS for replacments and paint trim ring.
Attached image(s) ![]() ![]() |
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 617 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
Nice - thx for posting! Always interesting to see custom work like this.
- Tony |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,955 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Early non quartz clock is a waste of time in my opinion. Please send all your non-functional early mechanical movement clocks my way (IMG:style_emoticons/default/laugh.gif) . . . . I love mechanical contraptions. Why else would I be playing with 50 year old cars (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 05:48 AM |
