ctc911ctc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 893 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States ![]() ![]() |
'74 2.0, 24K miles all original
Teeners, When I first got this car revived (it was parked in '84, I revived it in 2018) i left the shocks alone. IN 2019 I installed a nice system in the rear. This year I am doing the front - all bushings, and other rubber parts (ball joints). The project came to a halt, I cannot get the strut out of the cylinder ![]() I will rig a system to press it out later today I am checking in to see if there might be something I may be missing? I have hit is pretty hard to try and loosen it, no luck yet, soaked it with Liquid Wrench over night. ![]() Thanks! |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Tip the strut body upside down.
Look inside the ball joint hole. You'll see another hole that is in the bottom of the strut body that will allow you to tap the strut insert body with a long punch. That should do it with a few modest hits. If you're having to hit it seriously hard and it's not loosening, try a little heat on the strut body to free rust and to expand the strut bore slightly. FYI -- Those are aftermarket Bilstein inserts if you're not already aware and/or want to replace with same thing. |
ctc911ctc |
SUPERHAWK - I knew you would fly into this!
Seriously - I hit it with a large steel hammer and a large punch - did not budge.......I am replacing with OEM Bilstein (SP) - surprised that anything was changed in this car - the rears were seemingly all original. Will take and post a pic when I get it out! Tip the strut body upside down. Look inside the ball joint hole. You'll see another hole that is in the bottom of the strut body that will allow you to tap the strut insert body with a long punch. That should do it with a few modest hits. If you're having to hit it seriously hard and it's not loosening, try a little heat on the strut body to free rust and to expand the strut bore slightly. FYI -- Those are aftermarket Bilstein inserts if you're not already aware and/or want to replace with same thing. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Get some PbBlaster, pourable, and put some in the housing. About a pint for starters. Let it work to break any rust bonding. Then try driving the cartridge out again.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,341 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Not uncommon if the strut body is bent. Put a straight edge to it. - Seen it many times...
ctc911ctc |
I used liquid wrench - filled it up.........funny, none has leaked through the access hole on the bottom - YET
Get some PbBlaster, pourable, and put some in the housing. About a pint for starters. Let it work to break any rust bonding. Then try driving the cartridge out again. |
ctc911ctc |
******UPDATE***********
I went to the garage and it is still stuck - none of the Liquid Wrench has seeped through the hole at the bottom. I banged it a few times and it did not let go of the cartridge - also, the cylinder is straight. |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
If you decide to heat it up with a torch after pouring in any type of penetrating fluid, be careful not the breathe the fumes (IMG:style_emoticons/default/shades.gif)
Superhawk996 |
Here is what your dealing with at the bottom end of Bilstein strut inset for Boge strut bodies.
The metal body of a Bilsten insert actually holds the damping rod (it's inverted) and the actual valve body for the damper is up in the chrome "big" end that you see. This metal end cap is probably severely rusted to the strut body and/or has been jammed in there hard by hitting full jounce too many times. Also Bilstein's are pretty tight to the strut body since they need such a large tube to guide the upper inverted damper. Point being your Liquid Wrench / PB Blaster probably isn't even getting down to bottom where it's needed most. Invert strut and put the PB blaster in from the bottom though the ball joint and the other hole so it gets where it's needed. Can can get pretty aggressive with the hammer and the punch since you're hitting this gold colored steel end cap that is probably well rusted. Don't go 3 lb sledge on it though. Heat is your friend. Steel end cap ![]() |
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
Big slide hammer? I built one in high school and it removes just about everything.
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,507 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Or turn the housing up side down, in the press, with the punch.
Superhawk996 |
Uh oh! No update of success. (IMG:style_emoticons/default/sad.gif)
Superhawk996 |
Or turn the housing up side down, in the press, with the punch. This is a pretty good approach too. Need to be careful to press square and not bugger up the strut body threads. I'm thinking that you reinstall the gland nut at top of strut. But loosen it by about two turns giving just enough slack to budge the insert. That gland nut will help prevent deformation of the thin strut body tube and protect the threads simultaneously. Really would be surprised that it would take press forces to get it out. The one thing that bothers me is the Bilstein strut inserts since I don't have one to look at. "Real" Bilstein struts have the damper rod pinned in at the bottom of the strut housing with a roll pin that is very obvious. This is going way out there -- is there any thing like that going on with these struts and/or is the bottom hole behind the ball joint bore have some sort of a plug and/or threaded fastener in it? If no success so far . . . can you post a picture of the bottom of strut so we can see inside the ball joint bore and/or verify the damping rod isn't pinned like OEM Bilstein struts? @ctc911ctc |
ctc911ctc |
I went out yesterday and gave it a wack after soaking - did not budge
Will try the press and then heat - need to fashion a jig to perform the press. 2x4 should do the trick will send more as this progresses, Thank you SuperHawk Or turn the housing up side down, in the press, with the punch. This is a pretty good approach too. Need to be careful to press square and not bugger up the strut body threads. I'm thinking that you reinstall the gland nut at top of strut. But loosen it by about two turns giving just enough slack to budge the insert. That gland nut will help prevent deformation of the thin strut body tube and protect the threads simultaneously. Really would be surprised that it would take press forces to get it out. The one thing that bothers me is the Bilstein strut inserts since I don't have one to look at. "Real" Bilstein struts have the damper rod pinned in at the bottom with a roll pin. This is going way out there -- is there any thing like that going on with these struts and/or is the bottom hole behind the ball joint bore have some sort of a plug and/or threaded fastener in it? If no success so far . . . can you post a picture of the bottom of strut so we can see inside the ball joint bore and/or verify the damping rod isn't pinned like OEM Bilstein struts? @ctc911ctc |
ctc911ctc |
Well, it came out - the rust was right at the interface of the bottom of the receptacle and the bottom of the insert - the rust is minor, and the interface was water (oil) tight which makes absolutely no sense.
I tried pressing it out and after a few pumps I chickened out and turned it upside down and hit it with a drift........... popped out after I got aggressive THANK YOU FOR THE ASSISTANCE TEENERS! ![]() ![]() ![]() |
Superhawk996 |
Glad you got it out. (IMG:style_emoticons/default/smilie_pokal.gif)
The second picture confuses me. Looks like the yellow Bilstein strut insert has separated. What I mean by that is the small diameter damping rod (with the black jounce bumper) and it's associated end cap have separated from the yellow tube / body of the strut insert. How did that happen if you were driving the steel damping rod end cap downward into the yellow strut body? Doesn't really matter since you're replacing the inserts. Now that you have it apart like that, I'd love to see an internal picture of the yellow strut body. Can the large diameter chrome valve body be removed from the yellow outer tube? If so, you should be able to see a pair of teflon coated linear bushings (and some sort of seal to the large diameter chrome body) that guide the large diameter chrome valve body within the outer yellow tube. I'm wondering if they are the same setup as the original green Bilstein struts or some other variation? I'm also curious how the small diameter damping rod is secured to the bottom steel plate that you were hitting on. Is it welded or perhaps deformed into the end cap like a rivet or such? Sorry for the 20 questions, I've just never seen a Bilstein insert separated like that. @ctc911ctc |
Shivers |
Good news! Would only need a couple pumps to break it loose. I'm curious too, this is the inside of one of mine. Looks the same for the most part.
Superhawk996 |
Same principle for the damper - it's an inverted mono shock design that reduces sprung weight, has better valve response, and better cooling than a twin tube damper.
However, ctc911ctc has a aftermarket Bilstein strut insert in a Boge strut assembly. @Shivers , you have an actual Bilstein strut from a 911. You can tell these are from 911 by the seal cap which is much larger than the seal cap that was on the 914 Bilstein struts. The curved steering arm is also a 911 feature; 914 steering arm is straight. In your case, the damping rod is pinned into the bottom of your strut body and the larger diameter "insert" slides back & forth in the strut body and is guided by two Teflon coated bronze linear bearings. See PM. In the case of the aftermarket Bilstein strut cartridges that go into the Boge struts, the yellow (sometimes green) strut insert contains the guide bushings (theory on my part - I've never seen inside a yellow insert) - or at least I think so which is why I'm hoping @CTC911CTC will post a few pictures. |
Shivers |
Same principle for the damper - it's an inverted mono shock design that reduces sprung weight, has better valve response, and better cooling than a twin tube damper. However, ctc911ctc has a aftermarket Bilstein strut insert in a Boge strut assembly. @Shivers , you have an actual Bilstein strut from a 911. You can tell these are from 911 by the seal cap which is much larger than the seal cap that was on the 914 Bilstein struts. The curved steering arm is also a 911 feature; 914 steering arm is straight. In your case, the damping rod is pinned into the bottom of your strut body and the larger diameter "insert" slides back & forth in the strut body and is guided by two Teflon coated bronze linear bearings. See PM. In the case of the aftermarket Bilstein strut cartridges that go into the Boge struts, the yellow (sometimes green) strut insert contains the guide bushings (theory on my part - I've never seen inside a yellow insert) - or at least I think so which is why I'm hoping @CTC911CTC will post a few pictures. Yes, 1979 I think it was. I've got the other goodies too. A bit of work first. |
ctc911ctc |
I will post as many pictures as necessary to answer your questions Mr. S-Hawk!
I am going to powder Coat the A-Arm and Spindle assembly the same color as Mr. Shivers Speaking of Shivers, I have a cold, will get to it tomorrow - pictures that is. I have another project - the bead on the front right tire broke on my '17 Alpina B6.......need to remove and replace the tire......UGH |
Lo-Fi Version | Time is now: 1st July 2024 - 05:22 AM |
