cal914 |
Member ![]() ![]() Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None ![]() |
Has anyone got a pic of the wire colours for the 3 pin plug that goes into the back of the headlamp unit , I have one light on high the other low, then when I put it on high they swap over which is high and low so one wire must be in the wrong hole, a pic of a plug for a 1970 car would be great
Thanks Brian |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I've got my '76 torn down. Maybe they're the same. If looking at the back of the plug; white on the right side, brown on the left and yellow on top. (IMG:style_emoticons/default/beerchug.gif)
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
lierofox |
Member ![]() ![]() Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California ![]() ![]() |
If the wire colors at the headlamps look correct, the next spot I'd double check is the wires at the fuse panel and make sure those didn't get swapped around. The left and right high and low beams each get their own wire at the fuse panel, 4 total wires. Starting from the left side of the fuse panel, if you check the outgoing wires (the terminals facing the front of the vehicle) it should be 2 white wires (left and right high beams, respectively) followed by 2 yellow wires (left and right low beams, respectively.)
Lo-Fi Version | Time is now: 26th June 2024 - 01:25 AM |
