JMT |
Newbie ![]() Group: Members Posts: 36 Joined: 19-August 16 From: Ca Member No.: 20,316 Region Association: None ![]() |
Hello everyone. Went for a drive today and car ran great, stopped for fuel and when I started back up I heard a horrible rattle coming from cylinders 3 and 4 valve cover. After a tow home I found this. At least 1/4" gap from rocker to valve tip. I turned the engine over slowly and did get the rocker arm to slightly open valve. I thought how could a solid lifter collapse?
I also pulled the rockers and pushrod. The pushrod was not bent. I looked down the pushrod tube and saw 'C' clips on the lifters. Is there such a thing as solid lifters with 'C' clips? Thank's for the help. ![]() |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Probably not solid lifters, once the push rod is out you can pull out the lifter with your finger, after you remove the push rod tube.
JMT |
Thanks, I'm working on getting the tube out now without crushing it.
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,995 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Pushrod tubes aren't expensive. I spent hours trying to remove one without crushing it before finally taking the vice grips to it. Now I have one shiny one.
Good luck! Hope it's a simple fix. |
JMT |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Hydraulic lifter
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Better than a dropped valve seat.
JMT |
It was obvious that it’s hydraulic once I pulled it out. I was told this engine was built with a Webcam 86 so assumed it had solid lifters. Now what to do? Solid lifter swap.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
It was obvious that it’s hydraulic once I pulled it out. I was told this engine was built with a Webcam 86 so assumed it had solid lifters. Now what to do? Solid lifter swap. lifter brand and quality is often matched to the cam I believe cams for hydraulic lifters are mild there are a number of experts on here (not me) that can advise but my limited knowledge is that you may have to go back with another matching hydraulic lifter to work with that cam profile. or split the case and replace the cam with matching solid lifters brant |
sportlicherFahrer |
Nothing to see here. ![]() ![]() ![]() Group: Members Posts: 1,089 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest ![]() ![]() |
I'd double check with Web on that lifter. Their performance lifters look like hydraulic lifters, but somehow work as standard lifters. I just finished installing a set on my engine paired with their 86a cam. Threw me for a loop when I took the lifters out of the box.
I'd also compare the stem heights on the valves and do a leakdown check. Higher likelyhood that you have a dropped seat rather than a lifter issue. BTDT. |
rjames |
Have you taken the lifter apart yet? Wondering if the spring is broken.
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) if it was Hydro youd normally have other somewhat obvious signs like solid steel push rods (not the OE thick wall alum)
JMT |
(IMG:style_emoticons/default/agree.gif) I did see Webcam lifters that looked like hydraulic lifters. These look exactly the same.
https://www.pelicanparts.com/More_Info/WCAM...khoCI70QAvD_BwE https://aapistons.com/collections/lifters/p...-racing-lifters Oh, the pushrods are aluminum. |
sportlicherFahrer |
The ones you posted the Pelican link for are the exact ones I installed. Web's site lists them as mechanical, and they are still set with the normal lash the stock lifters use. Called them to verify after I unboxed them.
914werke |
pretty simple at this point to verify, pull another lifter & compare the two. My bet is they'll be the same. Looks like a seat.
Jack Standz |
Member ![]() ![]() Group: Members Posts: 295 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None ![]() |
Sorry to say, but based on your description (especially the noise), you're probably looking at a valve seat that let go.
Here's a very useful tool that you can feed either through the spark plug hole or manifold. It's useful for many other jobs too and is less than $20 delivered. Please note that this one works on an android phone. If you have an iPhone get a different one. https://www.amazon.com/gp/aw/d/B071HYRPND?p...ob_b_asin_title Best wishes with the fix. |
JMT |
Thanks guys. I have that same camera for Iphone. I'll measure stem heights and scope it tomorrow and get a leak down tester.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Do you have a dead sound when cranking the starter? The starter will make some noise when turning over a cylinder that has compression, and no noise (or rather, less noise) when turning over a dead hole.
Check the height of the valve tips when the valves are closed. If the one is lower than the others, something is holding it open. That something is usually the valve seat. --DD |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
From the picture, doesn't look like a dropped seat, a differential test would help confirm that. That rocker looks pretty far "back" compared to the others while the top of the stem looks in line.
If it's just a lifter, agree with others, ensure to confirm your cam, get a matched lifter. You may get lucky that's all it is. |
JMT |
Lo-Fi Version | Time is now: 25th June 2024 - 09:02 PM |
