jims914 |
Member ![]() ![]() Group: Members Posts: 125 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region ![]() ![]() |
Looking for a good large HD oil cooler and fan system
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Check with Chris at tangerine racing.
searunner |
Newbie ![]() Group: Members Posts: 16 Joined: 8-January 20 From: italy Member No.: 23,809 Region Association: None ![]() |
Looking for a good large HD oil cooler and fan system Some photos can help that a lot of words https://photos.app.goo.gl/zNtrmsvScM5MvC7k9 https://photos.app.goo.gl/HyoYwRqiXSSwSxM87 https://photos.app.goo.gl/J3pvgvRnpFD2Y4b87 https://www.ebay.com/itm/203459524797? epid=11047036250&hash=item2f5f21f8bd:g:uvMAAOSwBztgpKT~&amdata=enc%3AAQAHAAAA0NZtv%2FOTmvhYVZeTx0OUveXZeahYJXRSJ6zJLOoonmDjSaHHJ6%2FD9Zl5nQFmICw2OWQVOGqothhbI3fBO%2F6VDYaZy8fbDn2Hd1BMyQ8k0eSPDU%2BjuU70dpcz9RDhA78WCV6g6JjvxuqC6LQ%2BdUcQSMlCS9I46xDyn4XLsV%2Fe3SWy%2FRzH28ely6XdRjSw8rvXmXsHj9XgXI34hMdKgaw1%2FK0cW5bZlMaGozKg4Tf24GojANxjD6JO2yHy%2FpbSo7eRyW5xMwi64GBpPXJd0%2BhB8pc%3D%7Ctkp%3ABFBM2szR7dJg I have preferred the rear solution too easy to fit- for the filter adaptator my choice was for a termostatic adaptator - i have asked it to the supplier before the order and gently shipped with a little dollars more- now the car run in the Italian summer with 70°Calor oil temperature (Madium) fan is not termocontrolled and works continnualy is placed in the upper position to protect it from demages a little (2 cm) space allow the air circulation NOTE Kit illustred aren't the same build on my car- very similar but only the row are 15 to have a large cooling surface A lot of KIT are available - I haven't any commercial interest with this supplier |
jims914 |
Hello Searunner,
Sent a PM hope to hear from you. Ciao |
Geezer914 |
Geezer914 ![]() ![]() ![]() Group: Members Posts: 1,474 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Pegasus racing Setrab oil coolers.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Looking for a good large HD oil cooler and fan system Go for a large Mocal unit with their oil thermostat ,a quality fan which you can power up via a inline hose fitting with temp switch to activate it,if you mount it correctly for max airflow stood away enough from the underbody mounting you have a good solution. Not sure about other suppliers but the Tangerine adaptor is the way to go. Use quality rated hoses and have a good oil temp gauge you will be good. Cheers. |
914 Ranch |
Team Sharp where the 914 grow wings ![]() ![]() ![]() Group: Members Posts: 1,421 Joined: 29-January 16 From: TheNorth Shore Retreat. Deland Member No.: 19,611 Region Association: South East States ![]() |
914 Ranch |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Look at these :
http://www.914world.com/bbs2/index.php?showtopic=108328 |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Look at a front GT-style cooler and thermostat and be done with it. I have that set-up in my car and it never gets hot. No fans to worry about. Stays around 190-210 degrees depending upon weather. Yes, it is more money up front - but keeping your engine cool is what it is all about for longevity.
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Pegasus racing Setrab oil coolers. (IMG:style_emoticons/default/agree.gif) ![]() ![]() 180 deg Thermostat. 190 deg fan switch. |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,442 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
Nice...fancy version of my old 2.0/4 setup
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
Look at a front GT-style cooler and thermostat and be done with it. I have that set-up in my car and it never gets hot. No fans to worry about. Stays around 190-210 degrees depending upon weather. Yes, it is more money up front - but keeping your engine cool is what it is all about for longevity. Do you have the actual original size Setrab GT oil cooler? Mine runs a bit warmer on the race track with a cammed 3.2, street driving is fine. I talked to a race engine builder and he recommended another brand that builds custom coolers. I will see if I can look it up. |
Cairo94507 |
Look at a front GT-style cooler and thermostat and be done with it. I have that set-up in my car and it never gets hot. No fans to worry about. Stays around 190-210 degrees depending upon weather. Yes, it is more money up front - but keeping your engine cool is what it is all about for longevity. Do you have the actual original size Setrab GT oil cooler? Mine runs a bit warmer on the race track with a cammed 3.2, street driving is fine. I talked to a race engine builder and he recommended another brand that builds custom coolers. I will see if I can look it up. I have the cooler I bought from Patrick Motorsports from their GT cooler package. I believe it is a Setrab, but not certain. I also have the GT hard lines that run down the driver's long as well as the stock 914-6 engine oil cooler. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:33 AM |
