> 914-6 LSD, Did any 914-6 come with limited slip differential
DennisV
post Nov 3 2022, 08:44 AM
Did any 914-6 come from the factory with limited slip differential?
Based on what I see in the factory parts catalog, there is no reference to 914-6 that includes LSD.
If the answer is "yes" some came with LSD, is there a way you can tell by looking without opening the case?
Gustl
post Nov 3 2022, 08:48 AM
914 enthusiast & historian
Region Association: Austria
yes - it was the option M220
you can see it on the tag where the tranny-type and number is stamped in
I can show you an example pic, as soon as I'm home from office
post Nov 3 2022, 08:49 AM
914-6 GT in waiting
mgphoto
post Nov 3 2022, 09:19 AM
"If there is a mistake it will find me"
Search for the user Gustl he asked the same question and the answer was the number 914/01 10 for the first line says LSD 10 indicates 80/20 whereas 12 would indicate 60/40 slip settings.
sixaddict
post Nov 3 2022, 11:11 AM
So I was under impression if you turn output flange fwd the other side goes the same direction there is an LSD….you would not know OEM or aftermarket but that’s my 2 cents
Gustl
post Nov 3 2022, 11:52 AM
here is an example for a 914-6 transmission with LSD
and this one for a standard 914-6 transmission
914werke
post Nov 3 2022, 11:54 AM
mgphoto
post Nov 3 2022, 01:50 PM
QUOTE(914werke @ Nov 3 2022, 10:54 AM) *
Anybody remaking this tag?
I would really like to get one.
Cairo94507
post Nov 3 2022, 02:26 PM
Michael
@mgphoto I would shoot CarBone in Poland an email with that picture. It would not surprise me if they could get it done. (IMG:style_emoticons/default/beerchug.gif)
DennisV
post Nov 3 2022, 02:30 PM
QUOTE(mgphoto @ Nov 3 2022, 08:19 AM) *
Thanks for that suggestion. I think I found the thread you're referring to. Since there are no numbers following the 914/01, that suggests it is NOT LSD. Thank you.
schleups
post Sep 5 2023, 02:25 PM
I just purchased a 1974 2.0 liter - it has over 100,000 miles (odometer is broken - I plan to repair.)
Transmission code is "HB 02 05 3" which tells me it has limited slip. To my knowledge the transaxle has not been repaired; when on a lift the rear wheels rotate in opposite directions - implying no LSD evident. Is it possible that the LSD is still present but "worn out"?
Thank you for your thoughts/insights.
cjshpcoa@gmail.com
Charlie
post Sep 5 2023, 02:28 PM
914-6 GT in waiting
QUOTE(schleups @ Sep 5 2023, 04:25 PM) *
cjshpcoa@gmail.com
Charlie
It doesn’t sound like it has an lsd.
windforfun
post Sep 6 2023, 09:58 AM
Doesn't a LSD have to be disengaged at speeds above 5 mph? What's the difference between a LSD & posi-traction?
slivel
post Sep 6 2023, 11:52 AM
Old car....... older driver
QUOTE(windforfun @ Sep 6 2023, 08:58 AM) *
I would call LSD a generic term that could refer to a friction disc style limited slip or a torque biasing style. As I recall, posi-traction was a marketing term used by Chevrolet or GM for their LSD. My memory may be faulty on this and I'm sure someone on here can correct me if I'm not accurate.
flipb
post Sep 6 2023, 12:08 PM
QUOTE(slivel @ Sep 6 2023, 01:52 PM) *
Posi-traction was a GM trademark term.
And it was not available on the 1964 Buick Skylark!
Cairo94507
post Sep 6 2023, 02:36 PM
Michael
What a hottie!
Dave_Darling
post Sep 6 2023, 05:50 PM
914 Idiot
I believe the stock limited-slip uses clutches. They can and eventually do wear out. I don't know if they would make the car behave exactly like an open-diff car when they do, but it might.
Limited-Slip Differential is a broad term that encompasses many different types of diff, from locking diffs to clutch-type ones to worm-gear types (e.g., Torsen) and more besides. Posi-Traction is one specific type, and as noted above was specific to GM cars.
--DD
ClayPerrine
post Sep 6 2023, 06:12 PM
QUOTE(Dave_Darling @ Sep 6 2023, 06:50 PM) *
--DD
Yes, when any clutch type limited slip diff wear out the clutches, the diff then starts working like an open diff.
And you have to disassemble the diff, and replace the clutches. It is not an easy job. It takes some patience to get the clutch pre-load correct.
I much prefer Torsen style diffs. No clutches to wear out.
rgalla9146
post Sep 7 2023, 07:20 AM
QUOTE(ClayPerrine @ Sep 6 2023, 08:12 PM) *
--DD
(IMG:style_emoticons/default/agree.gif) I'm with Clay on that.
I have a 914 4cyl. trans (stamped HB, with Shell lube tag and
LSD diff carrier) that spins both hubs in the same direction.
So very likely clutches kaput.
technicalninja
post Sep 7 2023, 08:27 AM
QUOTE(ClayPerrine @ Sep 6 2023, 07:12 PM) *
That is an understatement!
I vastly prefer Torsens as well.
Only bad aspect of a Torsen is that it cannot be tuned. You cannot adjust how the clutches work because it has none.
Torsens are "road race" differentials in my book.
Drag racing requires a different approach and a standard clutch style or a true "locker" is usually better.
In the import world O.S. Gliken is the normal go to competition differential. These are completely adjustable clutch style and when you turn your Miata or S2000 into a track only car it is common to remove the Torsen (which it came with) and install a Gliken.
One thing to remember...
Clutch or Torsen vastly increases the temperature of the differential oil.
They only add the heat when they are functioning but if you're on a track where these are working a lot, adding some form of differential cooling is critical to the life of the differential. Clutches are far worse than worms in this respect but they both add big time heat.
- Lo-Fi Version Time is now: 26th December 2024 - 10:13 AM
