rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
I have a set of seats I want to recover but the left side head rest was burned when the heat from an engine fire caused the rear window to burst. I need a headrest including the wire frame it is bonded to. Here are photos of what I am looking for. I do not need the upholstery. If you have a junk seat laying around with a good headrest here is how you remove the headrest.
Remove the two screws from the hard covered panel behind the headrest. Flop it down against the back of the seat. Next look for two screws that go thru the fiber glas seat into the two small metal tabs welded to the headrest wire frame. The headrest should now be loose. ![]() ![]() |
KevinW |
Newbie ![]() Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest ![]() ![]() |
Rick,
I have a few extra seats I can send you one for the cost of shipping. Kevin |
rick 918-S |
Extra Thanks to Kevin!! (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 10:13 PM |
