914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,107 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I have a few early gauge frames that have been blasted & powder coated black.
These are the steel units found in cars through 74 when they switched to plastic frames. (IMG:style_emoticons/default/smile.gif) $50 + ship Available HERE (IMG:style_emoticons/default/bye1.gif) Attached image(s) ![]() |
porscheteck914 |
Newbie ![]() Group: Members Posts: 39 Joined: 23-March 23 From: n.c. Member No.: 27,247 Region Association: North East States ![]() |
I have a few early gauge frames that have been blasted & powder coated black. These are the steel units found in cars through 74 when they switched to plastic frames. (IMG:style_emoticons/default/smile.gif) $50 + ship Available HERE Hi , I ordered 1 off your site . Do you need metal cores so you can keep saleing these ? What does bump mean ? I see that a lot . |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,366 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
I have a few early gauge frames that have been blasted & powder coated black. These are the steel units found in cars through 74 when they switched to plastic frames. (IMG:style_emoticons/default/smile.gif) $50 + ship Available HERE Hi , I ordered 1 off your site . Do you need metal cores so you can keep saleing these ? What does bump mean ? I see that a lot . Bump to the top of the list. A way to get the item seen, again. |
914werke |
Do you need metal cores so you can keep saleing these ? Thanks but Ive got quite a few (IMG:style_emoticons/default/smile.gif) 1 remains from recent batch (IMG:style_emoticons/default/aktion035.gif) |
914werke |
914werke |
gtbarnes |
Newbie ![]() Group: Members Posts: 18 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States ![]() |
Hey. Wondered if you had any junk gauges to part with. I mainly just need the inside diffuser rings which hold the lens. One from each gauge type, combo, tach and speedo.
914werke |
Hey. Wondered if you had any junk gauges to part with. I mainly just need the inside diffuser rings which hold the lens. One from each gauge type, combo, tach and speedo. Shoot me a PM (IMG:style_emoticons/default/smile.gif) |
914werke |
I have a few of the late (plastic) frames as well ~ lightness! (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 26th February 2025 - 01:28 PM |
