Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Okay, I built an in-ground pond a few years ago...guess it's a few hundred gallons...it is surrounded by 2500 pounds of flagstone....after killing all 40+ goldfish last year*, I've let the pond dry up and now it's a trip hazard (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Now I'd like to rebuild it with a new and better pump and filter. But instead of keeping it in-gound, I'd like to raise it up and make a viewing window at least a foot or so from the ground level..basicly a one-window aquarium. Anyone have experiance with making something similar? Should I plexiglass or tempered glass? What about sealing it to the rest of the pond walls? *too much tap water into it when I drained it to clean it out some....poor fish (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
So I'm not an expert on aquariums or anything but... I predict in about 7 days the window will turn green, and in a couple weeks you won't be able to see the faintest amount of light thru it. Sounds like a bad idea. Plus the first time you hit a rock with the mower and shatter the window you'll kill another 40 goldfish. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 ![]() |
Google..
If you need new koi, I can work something out. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
I had a cousin back on the east coast (deceased now) who built several aquarium "walls" and used 1 inch thick tempered glass since they went to the ceiling. Remember the force of wather is about 1/2 pound per square inch per foot of height so the glass has to be pretty strong. If you are going up a foot or so then 3/8 inch should work okay. To seal it, I'd lay out the surfaces it sits against, seal them with a thin layer of concrete and then use GOOP sealer to glue the glass to it. If it were on a hill such as my back yard then the window could be much higher. This is on my todo list some day when I retire......
Mueller |
had a few Koi at one time also, I blame the death of those on my wife, she put too much fertilizer in the flowers right in front of the pond and it leached into it....poor guys.... |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,550 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I think you should use 914 glass pieces Mike....make it a 914 theme...maybe rear windows... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
snflupigus |
Member ![]() ![]() Group: Members Posts: 320 Joined: 29-May 05 From: Gilbert, AZ Member No.: 4,163 Region Association: None ![]() |
I'd use plexi... probably a TON cheaper but it scratches so it might quickly hase up from the inside out.
jgara962 |
Yo, this is how I roll ![]() ![]() ![]() Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California ![]() |
I built a 1,400 gallon koi pond with a stream and waterfall a couple of years ago. It is about 2 feet above the ground using interlocking blocks (10 pallets worth), my back aches just thinking about it. I can't make my picture smaller, so I will e-mail one to you. I've often sat on my patio thinking about the same thing. Biggest problem would be keeping it clean enough to see through, not to mention the possibility of leaks. My pond's enough work as it is.
Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
I wanna see a picture of your pond...post it here!
-Britain |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
Hmmmm....given the 914's history with rust, it almost sounds cruel to turn one into an aquarium. I guess on really cold days you could put the Targa on! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
jgara962 |
Hopefully this works...
Attached image(s) ![]() |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Nice pond.
I've always liked ponds...Used to work at the Embassy Suites Hotel. They had a fish pond. It had koi, goldfish and even trout! Mike, go for it! Sounds great. Here in Napa the herons are hungry and they swoop into the backyard ponds and get the fish that aren't protected by netting or mesh. (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) KT |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
Stop peeing in the pond and the fishies might stick around a little longer (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
airsix |
I have bees in my epiglotis ![]() ![]() ![]() ![]() Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 ![]() |
Mike,
Too much work. Just get one of these instead. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (I agree with the algae comments) -Ben M. Attached image(s) ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I do not have experience building ponds but use 1/2" to 3/4" tempered glass for fabricating glass railings. I can get you an aluminum base if you need it, but the best bet is to use Hilti epoxy to set your panels and pour rock to finish the glazing.
Let me know if you need a glass quote. www.rsnw.biz |
jgara962 |
Herons are a touchy subject with me (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I've been doing battle with one for over a year now. Not that I want it eating any of my fish, but for some reason, it ignores the goldfish and goes after the more expensive koi. I'll get it one of these days! (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) |
Brian Mifsud |
Mechanical Engineer ![]() ![]() ![]() Group: Members Posts: 981 Joined: 3-March 03 From: Penngrove, CA Member No.: 384 Region Association: None ![]() |
Mike,
Sunlight will degrade plastic over time. I'd go with the tempered glass, and just quit mowing the lawn (put in iceplant or "Italian Grass" (rocks......)) I put in a pond this summer (160 gallons) using a rigid liner, (and 4 truckloads of rock donated by our nearby mountains.....) The algae seems to "bloom" and diminish on and off. All the books say to use a U.V. filter which will sterilize and kill everything that flows by (like algae). I'm losing fish right now to "Ich"... it's pretty gross, when chunks of them rot off. The Salt treatment seems to have worked. Have fun. |
MikeP |
Member ![]() ![]() Group: Members Posts: 321 Joined: 13-June 05 From: San Jose, CA Member No.: 4,268 ![]() |
Yep go glass. You can get these very cool magnetic cleaners that go on either side of the glass so you can keep it super clean very easily.
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
Fill it back up with water & put new fish in it. Spend your money on your 914, like the rest of us. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Lo-Fi Version | Time is now: 18th June 2024 - 08:04 AM |
