> 914World Classifieds Rules
> Free:MSD 6A & Tach adapter, ********Claimef**********
jim_hoyland
post Jan 19 2023, 02:39 PM
Get that VIN ?
I removed the MSD after installing the 1-2-3 Ignition and it’s been sitting in a covered box since.
bob164
post Jan 19 2023, 03:36 PM
I will take the Jim, I can pick them up any time you like.
jim_hoyland
post Jan 19 2023, 04:28 PM
Get that VIN ?
QUOTE(bob164 @ Jan 19 2023, 01:36 PM) *
You got it Bob (IMG:style_emoticons/default/smile.gif)
bob164
post Jan 19 2023, 04:46 PM
Thanks Jim, you're the best!
rhodyguy
post Jan 19 2023, 11:14 PM
That setup works swell with a Unilite dist.
jim_hoyland
post Jan 20 2023, 09:02 AM
Get that VIN ?
QUOTE(rhodyguy @ Jan 19 2023, 09:14 PM) *
Exactly ! Before I installed the 1-2-3, there was a a Unilite. The 1-2-3 is far better; the optical sensor in the Unilite was a serious weak point.
Jack Standz
post Jan 20 2023, 10:16 AM
If you hook up the Unilite backwards, you will quickly burn up the optical sensor/module. So, don't do that. And you might consider getting a spare module or two if you want to run the Unilite., while they're still available.
Also, the vacuum advance version of this distributor can fail in a way that might harm your motor. Probably best to only use the centrifugal advance version only. With that said, they really are awesome distributors, especially considering the time theywere originally designed.
bob164
post Jan 20 2023, 04:40 PM
Thanks all for the advice and insight. I will start looking into the spare sensor.
- Lo-Fi Version Time is now: 30th January 2025 - 12:06 AM
