Rear Springs for my 914-6 GT Build? |
Tom1394racing |
Jan 22 2023, 02:46 PM
Member Group: Members Posts: 410 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
My 914-6 GT Tribute car will for sporting street use with a twin plug carbureted 3.2SS engine. I am not sure if I should be using 100 or 150 lb springs.
Any suggestions? |
scallyk9 |
Jan 22 2023, 03:06 PM
Member Group: Members Posts: 343 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I have a 1974 914 3.2L conversion that is running 140# rear springs but will be going to Weltmeister 180# progressive rear springs. The 140s did help with the additional weight and are only slightly more harsh for street driving than the 100# springs on my 2.0L LE. I don't have a rear anti-sway bar so I think the higher rear spring weight will be beneficial for track days.
mlindner |
Jan 22 2023, 04:09 PM
Senior Member Group: Members Posts: 1,603 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
mb911 |
Jan 22 2023, 04:57 PM
914 Guru Group: Members Posts: 7,422 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I use stock on mine. My car rides perfect
Cairo94507 |
Jan 22 2023, 05:37 PM
Michael Group: Members Posts: 10,173 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I have 140 pound springs on my car with Elephant Racing rubber bushings and Bilstein Sport shocks all around. Running a 3.2, stock bodied with deep 6 wheels. I also have F&R stock 914 sway bars. Car rides great. (IMG:style_emoticons/default/beerchug.gif)
East coaster |
Jan 22 2023, 08:32 PM
Senior Member Group: Members Posts: 1,801 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
I had 165 progressive rate springs on my 3.6 car and loved them for the street.
infraredcalvin |
Jan 23 2023, 03:00 PM
Distracted Member Group: Members Posts: 1,581 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
I think I have a set of 165 progressives…. Let me know if you’re interested and I’ll look for them and post some pics, would be looking for $100 plus shipping and any fees.
Justinp71 |
Jan 23 2023, 04:03 PM
Senior Member Group: Members Posts: 1,606 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I run 200lb rear springs on my 3.2 conversion car. Doesn't seem stiff at all with the 15" tires. I also used to some track and ax, so I liked being a little stiffer. I had a 2013 GTI for a while that car was much stiffer (IMG:style_emoticons/default/smile.gif). |
Steve |
Jan 24 2023, 08:04 AM
914 Guru Group: Members Posts: 5,780 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I ran 140’s in the rear with my 3.2 and 914 trans. Had to upgrade to 200 when I switched to the 915 trans and heavier 108mm cv’s.
slivel |
Jan 24 2023, 10:59 AM
Old car....... older driver Group: Members Posts: 516 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California |
During the years of Club Racing, I ran a variety of spring rates. At the end of my racing days I was at linear rate 450 front, 400 rear. Now as just a street toy, I am running progressive rate stacked springs with an effective rate in the droop/compression regime for my car of 150-270 front and 230-330 rear. Spring rate at the shock for the rear is 161-248. The higher effective rate is corrected for the motion ratio of the rear suspension which is about 1.3 for the 914.
If you stick with linear rate springs, they are inexpensive and really easy to change on the rear. I have two crates of linear rate springs that go anywhere from 250 to 700. My car is sprung a little too stiff for the street, but I don't drive it enough to warrant a change plus I do like the way it handles. |
r_towle |
Jan 24 2023, 02:37 PM
Custom Member Group: Members Posts: 24,699 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
140 rears, stock front torsion bars
Add an adjustable front anti sway bar to help tune the front stiffness. I would suggest adjustable koni shocks all around I have 180 rears, bilstiens all around Car it too stiff. |
Chris914n6 |
Jan 24 2023, 03:24 PM
Jackstands are my life. Group: Members Posts: 3,431 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I got talked into 180s when I did the swap. Dropped back down to 140s and it rides and turns better.
Front end is stock 911 Carrera. Turns out the weight increase wasn't really that big. |
r_towle |
Jan 24 2023, 03:26 PM
teeth and lower back cost money to fix.
mb911 |
Jan 24 2023, 08:34 PM
Miguel K R |
Feb 20 2023, 04:51 AM
Newbie Group: Members Posts: 20 Joined: 12-December 19 From: Portugal (Europe) Member No.: 23,732 Region Association: None |
Hi,
I am building a 914-GT replica and I am confused with the spring rate recommendations for Street use. Without getting into the specifics of my car (weight of a 993 engine and Boxster S trans) I often see people suggesting 140-160Lb/in springs, or 160 or 180 progressives. I guess that is for using with Bilstein shocks without threaded adjustment (I guess those springs have a 4.1 to 4.25" Outer Diameter, and a Free Length of 15"). On the other hand, Patrick Motorsports sells threaded adjusters and for Street they recommend 175-225 Lbs springs (I would consider 225 Lbs due to my heavier engine and trans). They mention that these are 2.50” I.D. x 8.0” Length It does not matter if a Spring is short or long, if it has a small or large diameter, nor its preload. Once he suspension starts going down, for each Inch of stroke the spring applies an extra force in Lbs determined by its spring rate. This means that Patrick Motorsports recommends stiffer springs, or am I missing something ? |
Cairo94507 |
Feb 20 2023, 08:14 AM
Hi Miguel, I think you have a good understanding of springs. PMS is an excellent shop and I am know they have done many 993 engines in 914 projects. So they speak from experience. (IMG:style_emoticons/default/beerchug.gif)
zoomCat |
Feb 20 2023, 09:06 AM
Member Group: Members Posts: 187 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
Here’s what the factory thought:
I don’t know the actual source of this data, though. |
Justinp71 |
Feb 20 2023, 01:26 PM
Each to their own really depending on usage and local roads. I would not want anything less than 200lbs with 15's for what I use the car for. Mountain driving and occasional track.
Here is what Patrick Motorsports says for what that is worth- "For street use setup we recommend (175-225 lbs spring set) – For full racecar setup we recommend (275- 325 lbs spring set). The system allows infinite ride height adjustability and corner weight balance setup. Part # SUS 914 RCKIT and PMP914." |
Lo-Fi Version | Time is now: 15th January 2025 - 01:11 AM |
