A few 914-6 cases |
A few 914-6 cases |
Unobtanium-inc |
Feb 1 2023, 04:52 PM
Advanced Member Group: Members Posts: 2,289 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
Rob at DC just posted this, in case anyone is feeling lucky!
Attached image(s) |
SirAndy |
Feb 1 2023, 04:57 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So close (IMG:style_emoticons/default/blink.gif)
Looking for 6404159 ... (IMG:style_emoticons/default/idea.gif) |
Cairo94507 |
Feb 1 2023, 05:19 PM
Michael Group: Members Posts: 10,173 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
@SirAndy .... Man, that is so so so close. I would be tempted to try to buy that case just so you at least have an almost spot-on case and at least it is the period correct 914-6 case.
I have a '71 914-6 case that is about 20 numbers off my original case just to have a correct 914-6 '71 case in the event I ever sell the car or decide to do another engine. (IMG:style_emoticons/default/beerchug.gif) |
rhodyguy |
Feb 1 2023, 05:24 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
2 digits. I could pull the trigger on that one. If I needed a 6 case. Anyone inquire about pricing?
rick 918-S |
Feb 1 2023, 09:18 PM
Hey nice rack! -Celette Group: Members Posts: 20,840 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Close 4371
horizontally-opposed |
Feb 1 2023, 09:25 PM
Advanced Member Group: Members Posts: 3,453 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
@SirAndy .... Man, that is so so so close. I would be tempted to try to buy that case just so you at least have an almost spot-on case and at least it is the period correct 914-6 case. (IMG:style_emoticons/default/agree.gif) |
zoomCat |
Feb 1 2023, 10:45 PM
Member Group: Members Posts: 187 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
2 digits. I could pull the trigger on that one. If I needed a 6 case. Anyone inquire about pricing? I believe they’re listed for $4k on the website. https://www.dcauto.com/parts/78382?illustra...1&year=1970 |
gms |
Feb 5 2023, 10:10 AM
Advanced Member Group: Members Posts: 2,708 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
I will caution anyone thinking about doing business with DC Auto and Rob, their idea of a rebuildable motor is different then mine. In fact the only usable part my engines came with were the cases.
gms |
Feb 5 2023, 10:17 AM
after the engines arrived I immediately pulled them apart and here is what I found
cam tower so twisted the rocker arms were stick The other cam tower was junk, both sides were Left cams still wet and rusty |
gms |
Feb 5 2023, 10:21 AM
GregAmy |
Feb 5 2023, 10:26 AM
Advanced Member Group: Members Posts: 2,422 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
When the point is to get the right case number so that you can burn into a $pendy concour$e re$to to sell your 914/6 to a big money collector for stoopit money...well, dem's the breaks...
Edit: after all, those engines were pulled from their original home for a reason: no one wanted them, most wanted to swap in a bigger engine. So it seems reasonable that they led a pretty ugly life... |
gms |
Feb 5 2023, 10:31 AM
gms |
Feb 5 2023, 10:33 AM
I sent this to Rob and he sent me a set of 80 mm heads without valves and some useless pistons pistons
Engine 1 914/6 air cleaner- melted Air cleaner snap cans – rusted thru Weber IDA carbs – broken air correction screw, seized throttle shafts Missing linkage cross bar, reverse lever and mounting brackets Cam shafts pitted Both cam towers – gouged cam bearing areas, second twisted Oil Cooler – crushed & does not hold pressure Heads (2.0 L1819d 911T) fly cut to 2.2L, inconsistent combustion chamber volumes, many studs missing 2.2L pistons and cylinders – water damaged, cylinders sanded Missing 2 rear engine transmission mounting studs m10x105mm (999.062.099.02) Engine 2 Only 1 K&N filter Zenith cards - seized throttle shafts, incorrect for 914/6 Alternator ring cracked (fan and alternator acceptable) Missing linkage cross bar, reverse lever and mounting brackets fiberglass engine shroud - broken mounting holes, Incorrect version Oil Cooler – AN? fitting welded to bottom 2.2L pistons and cylinders – mismatched set, water damaged, cylinders sanded Oil pump - Seized Missing flywheel Missing 2 rear transmission mounting studs m10x105mm (999.062.099.02) |
Cairo94507 |
Feb 5 2023, 10:47 AM
Thanks for the heads-up about DC Auto and Rob. Finding trusted suppliers is always a gamble and anxiety ridden. I have been burned a couple of times while gathering parts for my car. Fortunately for me the parts I was burned on were not that expensive. (IMG:style_emoticons/default/beerchug.gif)
sixnotfour |
Feb 5 2023, 11:24 AM
914 Wizard Group: Members Posts: 10,704 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
I have 3 also ...Bare Cases
6414053 6404034 6405482 1k each offer.. |
Superhawk996 |
Feb 5 2023, 11:36 AM
914 Guru Group: Members Posts: 6,663 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Weber IDA carbs – broken air correction screw, seized throttle shafts Post to classifieds if you don’t want to deal with fixing them. I’m interested at the right price point that reflects need for machine work and a Total Overhaul. Whatever you do, don’t scrap them! Same on the plastic air cleaner assembly. |
Unobtanium-inc |
Feb 5 2023, 09:11 PM
I've done well at DC, but I left with a truckload of cars.
Attached thumbnail(s) Attached image(s) |
davep |
Feb 6 2023, 08:44 AM
914 Historian Group: Benefactors Posts: 5,227 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Adam, you had a better result due to ton's of experience and inspecting in person while making the purchase. Meanwhile Glenn got a pig in a poke.
Steve |
Feb 6 2023, 09:01 AM
914 Guru Group: Members Posts: 5,780 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Adam, you had a better result due to ton's of experience and inspecting in person while making the purchase. Meanwhile Glenn got a pig in a poke. (IMG:style_emoticons/default/agree.gif) Its easier when you go and inspect the parts yourself. I've had good luck and bad luck with DC Auto. The last part i bought was a 911 front suspension bottom cover. It was rusted and banged up pretty bad. I threw it away and bought a new one for not much more money. Also beware of LA Dismantler. I bought a motor from them and as soon as I got it home I did a leak down test and 3 of the 6 cylinders were really bad. They said I was not a "real" shop, so too bad. By the time I could get into a real shop, the warranty was gone. I should of did a leak down before pulling the exhaust and other stuff off of it. I would also recommend getting the warranty in writing and make them do a leak down in front of you. |
Lo-Fi Version | Time is now: 15th January 2025 - 06:33 AM |
