Wheel Fitment Question, '73 narrow body |
76-914 |
Feb 1 2023, 08:58 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,654 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm in the process of collecting parts for my 5 lug conversion and wanted to ask if a 71.6mm Bore. 52mm Offset 5 x 130mm Bolt Pattern 17" x 7" wheel would fit. I believe they were on the 968's, maybe Boxters. TIA, Kent
rick 918-S |
Feb 1 2023, 09:16 PM
Hey nice rack! -Celette Group: Members Posts: 20,840 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I'm in the process of collecting parts for my 5 lug conversion and wanted to ask if a 71.6mm Bore. 52mm Offset 5 x 130mm Bolt Pattern 17" x 7" wheel would fit. I believe they were on the 968's, maybe Boxters. TIA, Kent (IMG:style_emoticons/default/icon_bump.gif) not sure about that but I thought I remember someone with Boxster wheels on their14. |
NARP74 |
Feb 2 2023, 09:32 AM
Senior Member Group: Members Posts: 1,308 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I have some printed pics of mine with what I think are Boxster wheels installed before I bought it. By the time I got it, Fuchs were installed. The pics were from a for sale ad that is gone now. It is a narrow body.
Chris H. |
Feb 2 2023, 09:39 AM
Senior Member Group: Members Posts: 4,053 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Should fit Kent. Mine are 17x7, 55 offset (I think they're same wheels you have on your orange car). You will need some spacers and longer studs. I have 15mm on mine. You can use the orange car wheels as test mules.
76-914 |
Feb 2 2023, 10:52 AM
Should fit Kent. Mine are 17x7, 55 offset (I think they're same wheels you have on your orange car). You will need some spacers and longer studs. I have 15mm on mine. You can use the orange car wheels as test mules. The orange/red car has flares so I was doubtful but I'll check. (IMG:style_emoticons/default/beerchug.gif) |
Chris H. |
Feb 2 2023, 12:24 PM
I should mention that the original set that came on a Boxster would be 7x17 front, 8.5x17 rear. Mine are all "fronts" so make sure you verify that (IMG:style_emoticons/default/beerchug.gif) . They're snug but they fit.
Chris914n6 |
Feb 2 2023, 12:46 PM
Jackstands are my life. Group: Members Posts: 3,431 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
What kind of fool would want to do that?? (IMG:style_emoticons/default/av-943.gif)
All studs are 944 rear. I'll have to look at what spacers I ended up with. 15mm and 21mm I think. 225/45-17 (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1659214723.1.jpg) |
Chris H. |
Feb 2 2023, 05:26 PM
Yeah those are exactly the wheels I have Chris. They look cool in red! 225s must BARELY fit in the rear. I'm @ 215/45/17 and there's very little space.
Cairo94507 |
Feb 2 2023, 06:08 PM
Michael Group: Members Posts: 10,173 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Just be careful with the rear fender clearance; static they might be fine, but once you are driving and in a sweeper at speed, you might experience some rub. Of course check the fronts for full turning clearance and make sure if the front suspension is compressed in a turn at speed you don''t catch a lip. (IMG:style_emoticons/default/beerchug.gif)
76-914 |
Feb 2 2023, 06:33 PM
Great info from the 2 Chris' and Cairo.Thx for the tire sizes as that would have come up eventually (IMG:style_emoticons/default/beerchug.gif) . Thx
Chris914n6 |
Feb 2 2023, 09:16 PM
The Indy500 are a tad narrow at the tread which is good as the fronts are tight.
The rears are fine as I got a bit carried away with the roller. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394178.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394179.2.jpg) 235/70-15 anyone? (IMG:style_emoticons/default/w00t.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394179.3.jpg) |
76-914 |
Feb 2 2023, 11:18 PM
The Indy500 are a tad narrow at the tread which is good as the fronts are tight. The rears are fine as I got a bit carried away with the roller. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394178.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394179.2.jpg) 235/70-15 anyone? (IMG:style_emoticons/default/w00t.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1675394179.3.jpg) Chris, do you have a pic showing the clearance between the front tire at the rear of the front wheel? And yes, you did get carried away with those rear wheels. (IMG:style_emoticons/default/biggrin.gif) |
Chris914n6 |
Feb 6 2023, 06:12 PM
Spacers:
21mm front (944 early rear) 21+5mm rear Factory alignment. I figured the short sidewall preferred minimal camber. |
Lo-Fi Version | Time is now: 15th January 2025 - 02:47 AM |
