fuel pump relocation under steering rack pictures? |
Geezer914 |
Feb 4 2023, 08:57 AM
Geezer914 Group: Members Posts: 1,819 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Anyone relocated the fuel pump and filter under the steering rack with to make it easier to change the fuel filter? Pictures? Thanks
FlacaProductions |
Feb 4 2023, 09:48 AM
Senior Member Group: Members Posts: 1,863 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Geezer914 |
Feb 4 2023, 10:57 AM
Thanks for the pic.
Literati914 |
Feb 4 2023, 11:11 AM
Senior Member Group: Members Posts: 1,799 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I’m planning the same .. any more pics out there? A few different angles would help clear the mind tbh (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/smoke.gif)
FlacaProductions |
Feb 4 2023, 11:37 AM
FlacaProductions |
Feb 4 2023, 11:46 AM
I know...I know....I don't like the blue crimp connector either but that's the PO's work. I'll get that corrected.
mlindner |
Feb 4 2023, 12:13 PM
Senior Member Group: Members Posts: 1,603 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
roundtwo |
Feb 4 2023, 12:18 PM
Member Group: Members Posts: 311 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Geezer, not what your looking for but just to give you ideas. With my forward install fuel tank I mounted the filter and pump under the tanks for easy service. Mark Hello, Do you have a fuel filter before the fuel enters the fuel pump? And is that metal bracket to cradle of the spare tire? Nicely done. Thanks.Todd |
mlindner |
Feb 4 2023, 12:26 PM
rhodyguy |
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,207 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
I would not like having to remove the rack cover piece to simply change the filter or service the lines or the pump. ESP potentially on the side of the road.
FlacaProductions |
Feb 4 2023, 12:47 PM
Geezer914 |
Feb 4 2023, 02:53 PM
Rhodyguy, if the pump or the filter craps out, that is something I would not attempt to fix on the side of the road. With the fuel pump under the gas tank, it's a pia to remove the plate and maneuver the fuel pump with the 12mm fuel line to get the filter out , and stuff everything back in hoping you didn't kink a fuel line. Under the steering rack, you remove 4 bolts and everything is right there. I would like to install a small fuel shutoff valve to make it easy to change the filter.
windforfun |
Feb 4 2023, 03:23 PM
Advanced Member Group: Members Posts: 2,019 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
I would not like having to remove the rack cover piece to simply change the filter or service the lines or the pump. ESP potentially on the side of the road. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
mlindner |
Feb 4 2023, 04:44 PM
Just pinch the fuel line for that.
iankarr |
Feb 4 2023, 06:20 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,532 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
The factory solution placed the pump in the tank well…with an access cover that could be removed from the frunk. I think that’s the most elegant stock solution. On my bumblebee I located the pump next to the steering rack, but it was tricky to get the hoses routed so there were no kinks. And no impact to the steering.
JeffBowlsby |
Feb 4 2023, 09:03 PM
914 Wiring Harnesses Group: Members Posts: 8,806 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that.
JamesM |
Feb 5 2023, 02:41 AM
Advanced Member Group: Members Posts: 2,032 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that. Don't own a 75-76 car then i guess. (IMG:style_emoticons/default/confused24.gif) With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. |
wonkipop |
Feb 5 2023, 03:20 AM
Advanced Member Group: Members Posts: 4,670 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
A concern with the front mounted pumps is that pressurized fuel is now routing through the cabin. I’m not comfortable with that. Don't own a 75-76 car then i guess. (IMG:style_emoticons/default/confused24.gif) With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. on the other hand stainless steel is brittle! i've done the metal lines, but i bent them up myself out of mild steel tube. just a thought. but you are right. something else in the 50 year old car is bound to do you malicious harm in a stack - before the fuel lines finish you off. (IMG:style_emoticons/default/sad.gif) |
TX914 |
Feb 5 2023, 05:23 AM
Alan-B Group: Members Posts: 177 Joined: 27-July 14 From: USA Member No.: 17,689 Region Association: None |
I have a 76 and I appreciate the stock pump/filter location with access through the front bulkhead. I once got some bad gas that left me stranded on the road and it was relatively easy to drain the tank by disconnecting the filter. Also easy to change the filter and inspect for leaks. I think the factory got it right.
barefoot |
Feb 5 2023, 08:18 AM
Senior Member Group: Members Posts: 1,337 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
With a swap to stainless lines and the center tunnel being a mostly enclosed metal tunnel with the few small openings under carpet I think ones chances of being directly exposed to gasoline from having the lines under pressure are very, very low. At its worst I dont see it as anymore dangerous than anything else about driving a very small 50+ year old car. Also I find it very preferable to vapor lock, especially on long trips. [/quote] on the other hand stainless steel is brittle! i've done the metal lines, but i bent them up myself out of mild steel tube. just a thought. but you are right. something else in the 50 year old car is bound to do you malicious harm in a stack - before the fuel lines finish you off. (IMG:style_emoticons/default/sad.gif) [/quote] I question your comment about SS being brittle, I've spent many years with SS in aircraft fuel systems and unless SS tubing is flexed to the point of fatigue failure it is not brittle. Fatigue failure would require many hundreds of flexes to near plastic bending to behave in a brittle fashion. |
Lo-Fi Version | Time is now: 15th January 2025 - 06:55 AM |
