> Pedal floor boards, Is there a way???
nivekdodge
post Feb 15 2023, 08:11 PM
Little things are annoying me. Is there a process to get the floor board back aroung the pedals without disconnecting the accelerator from the cable?
Kevin
bdstone914
post Feb 15 2023, 08:18 PM
bdstone914
No need to remove the cable. Remove the two bolts that mount the pedal to the floor. If they are rusty soak with a good penetrant.
Remove the pedal covers. Hold the board horizontal and slide onto the top of the pedals and then down.
post Feb 15 2023, 08:43 PM
It help to remove the rubber pads from the brake and clutch pedals. (IMG:style_emoticons/default/beerchug.gif)
914 RZ-1
post Feb 15 2023, 09:17 PM
Porsche Padawan
It's not easy, but it can be done. It's like a puzzle that only goes together one way. I can't remember exactly how I did it, but you twist and turn and it will go over the pedals. It's hard to explain! Patience!
Garland
post Feb 15 2023, 11:56 PM
Restoration Fanatic
QUOTE(914 RZ-1 @ Feb 15 2023, 10:17 PM) *
Pop the Excelerator rod off the back of the excelerator pedal. Then the board will go in, with some movement of the clutch and brake pedal’s.
nivekdodge
post Feb 16 2023, 12:31 PM
QUOTE(Garland @ Feb 16 2023, 12:56 AM) *
But then to get the accelerator rod back in I have to remove the floorboard (IMG:style_emoticons/default/sawzall-smiley.gif)
dr914@autoatlanta.com
post Feb 16 2023, 12:55 PM
YES Just snap the rod off of the pedal and remove the two pedal pads and then the two allen bolts and turn at an angle to remove
QUOTE(nivekdodge @ Feb 15 2023, 07:11 PM) *
Kevin
Garland
post Feb 16 2023, 01:02 PM
Restoration Fanatic
QUOTE(nivekdodge @ Feb 16 2023, 01:31 PM) *
Only remove from back of pedal socket. Just pull, the pedal towards you.
930cabman
post Feb 16 2023, 03:02 PM
QUOTE(76-914 @ Feb 15 2023, 09:43 PM) *
Yes, and wiggle her in there
nivekdodge
post Feb 16 2023, 08:22 PM
THanks Guys,
I did get it back on !!!!
Kevin
- Lo-Fi Version Time is now: 15th January 2025 - 12:31 AM
