> 914World Classifieds Rules
> FS: 15x7 Braid 3-piece wheels
driver27
post Feb 28 2023, 11:36 PM
Hi All,
Selling a set of Braid Serie 1 Campagnolo-style wheels with Toyo Proxes R888 tires.
I swapped over to 5-lug 911 brakes on my 914, sadly can no longer use these. (IMG:style_emoticons/default/sad.gif)
These are lightweight real deal 3-piece wheels that were special ordered ($2900 new). They're in perfect shape, no scratches, markings, or curb rash.
Measurements:
15" x 7"
+23 offset
4 x 130 bolt pattern
71.6mm hub bore
lug style is M14 ball (lug bolts included if you need them)
These will fit all 914-4 from '70-'76, as well as '68-'77 VW Beetle
Tires are Toyo Proxes R888 in 195/55R15 85V
They are basically down to the wear bars, although you can probably get another few hundred miles out of them (or use them as track tires). Date code is from 2016.
$2200 $1900 OBO
Located in San Fernando Valley but will deliver within reasonable distance.
Can remove tires and ship wheels at buyer's expense, but would prefer local pickup.
Thanks for looking! Attached Image Attached ImageAttached ImageAttached Image[attachmentid=868
024]Attached ImageAttached ImageAttached Image[attachmentid
=868022]
fasthonda
post Mar 1 2023, 08:11 AM
914 Type R
Those are sweet. Too bad they are not 5 Lug. Should sell fast.
914werke
post Mar 1 2023, 09:35 AM
I like them. How much do they weigh?
Craigers17
post Mar 1 2023, 10:38 AM
I've been looking at these same wheels on their website for about 6 months now. I love these wheels, but personally don't want to go any wider than 6". BTW these retail for about $850 a piece....so looks like a great deal!
914werke
post Mar 1 2023, 10:47 AM
QUOTE(Craigers17 @ Mar 1 2023, 08:38 AM) *
Given they are 3 piece wheels you should be able to pu some .5's & get the width & offset you after (IMG:style_emoticons/default/idea.gif)
driver27
post Mar 1 2023, 11:02 AM
QUOTE(914werke @ Mar 1 2023, 07:35 AM) *
I've actually been meaning to weigh them to compare with the 5-lug cookie cutters that I put on to replace them. By my estimation they seem pretty close, but I will make sure to get an exact number for you (with tires mounted) by this Friday. Thanks!
driver27
post Mar 27 2023, 12:10 PM
bump, price dropped!
also, weight for one wheel/tire assembly is 34.8 lbs (guessing the wheels themselves are about half that)
- Lo-Fi Version Time is now: 30th January 2025 - 04:29 PM
