bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,004 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
I know we have threads about PO stupidity, but how about the dumbest 914 thing you have done?
I will start with a, ahem, senior moment I had today. When I tried to add oil after my recent engine re-installation, it would not go in. Short version: I forgot to remove the paper towels I had folded up and tucked into the breather recess while the engine was out of the car, to keep anything from falling into the case. I still can't believe that I installed the breather and did not see and remove paper towels. Attached thumbnail(s) ![]() |
Craigers17 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 779 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States ![]() ![]() |
I did something very similar a couple months ago. I was changing out manifolds, carbs, and air cleaners. I installed the new manifolds and then put the gaskets on top. At that point, I stuffed a balled up blue shop towel down each manifold intake to keep from dropping anything into the engine while I did the other side.
SOMEHOW, when I placed the carb down onto the manifold, I forgot the towels were there, even though they were in plain sight. Luckily, when I went to hook up the throttle linkage, I started dicking with the throttle and it wouldn't open freely. The throttle plates were hitting on the towels. That's when I realized what an idiot I am.....again. Crisis avoided. I'm just getting old apparently. |
930cabman |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,481 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States ![]() ![]() |
Last winter I built a 2056, got her on the stand and was unable to get oil pressure while cranking. Tried, tried, finally I said maybe she will get some pressure when she fires up. Sure enough she fired and still no pressure! Took it apart and had a small ball of paper towels in the pipe leading to the oil pump. Got her all together and she runs like a champ.
Most of us are getting older everyday, some more than others BTW: great build Bob there is bound to be some of the greatest moments to follow. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,604 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Last week my turn signals quit working on a short drive to the store. When I came home I checked fuse 7 and it was good but since it had the fuse panel upgrade - done by others - I checked them all to no avail. Well crap, it was time to dive into it. Removed the lower knee pad dropped the fuse panel, Emergency flasher switch, headlamp switch & Fog Lamp switch - can't remove just the one by itself. The Emergency Flashers worked but I tested the flasher relay anyway and of course it was good. I even opened it up to check the contact points. Next I checked for continuity between 48 & L/ R on the Emergency Flasher switch to confirm that the Turn Signal switch was good and yes it indicated so. Being the optimistic idiot I've become I installed a spare switch and still No Worky! Not trusting myself - I'm sure the neighbors think I'm giving my wife the business as I'm always verbally abusing myself in the garage - I removed the Turn Signal switch in hopes that I would find a dropped pin, etc. Everything looked OK but I changed it out with a NOS one in my stash and that didn't correct anything either. (IMG:style_emoticons/default/headbang.gif) Now at wits end I decided to check the true signal lamps and found the loose spade connecter on the left Tail Lamp bucket. The 1st damned thing I should have checked but NOOOOOOOO! I had to piss off a few hours instead of checking the easiest & most common failure point in that system. (IMG:style_emoticons/default/fyou1.gif)
gandalf_025 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,467 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States ![]() |
I had a body shop cut down my 914-6 rear snowplow valance
to make it look like the newer cars.. Also painted the white headlight surrounds black to look more modern.. This was done around 1974.. ![]() |
gandalf_025 |
I also bought a complete 1965, 911 engine
over an hour away from my house and brought it hone in a 1966 MGB… ![]() |
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,936 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
Drove my new Scirocco too close to the curb at a fucking toll booth.
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,542 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
Daughters first time driving, I pulled into an empty parking lot and let her drive my S4, within 30 secs she ran over a planter island, cost me a new tire and a nice ding in my rim. I had just gotten new tires the day before…
I bought a 3 liter 911 engine with a few broken head studs. I was going to fix the studs, put back together and perform a leak down, hoping for a quick fix. All kinds of horror stories about piston circlip dropping in the case - I know better, but continued to pull pistons without covering spigot holes… last one, the clip sprung out right into the case—- wasn’t able to find it, so now she’s getting a full tear down… I’ve got plenty more… |
DBF |
Member ![]() ![]() Group: Members Posts: 92 Joined: 29-August 21 From: Wisconsin Member No.: 25,865 Region Association: Upper MidWest ![]() |
Wanted to celebrate my birthday by doing some work on my car. I was replacing the gear lube in my transmission and stuck a short piece of rubber tubing on the end of the gear lube container to keep from spilling gear lube. When I squeezed the bottle the tubing shot into the transmission. I spent most of the day trying to fish out the tubing with no luck. Finally took the car for a drive and flushed the transmission - 4 times. 150,000 miles later and the transmission still shifts fine.
914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I took my transmission out, but, when putting it back in, forgot to install the throw-out bearing ("What is this extra part?"). I had to take the trans out again, by myself, and install the throw-out bearing, then put the trans back in, by myself.
jhynesrockmtn |
Member ![]() ![]() Group: Members Posts: 425 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest ![]() ![]() |
I had pulled the engine on my 70 to fix a bunch of leaks and freshen things up. The trans, exhaust and bottom of the engine were caked with oil and trans fluid. I cleaned everything up including the heat exchangers. The good news, the leaks were solved. The bad news, I didn't clean the inside of the heat exchangers which now had a combination of cleaning solution mixed with greasy gunk in them. I had to pull the heater parts back off and using a hose, towels, and stuff to push and pull the towels I managed to clean the inside good enough without pulling them off the car.
930cabman |
Thanks all for the laughs, keep them coming
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,781 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
probably a dozen things.... we should call these the DACO " dumb ass current owner"
my" DACO" moment that first comes to mind is recent--- I have had my motor and trans out 4-5 times for various reasons, but recently pulled to do the RMS and some push rod tube seals etc, removed tin to clean and inspect etc and that means the distributor had to come out, well everyting goes back in just like it came out , ites all back together, it should start right up, unless of course you dont make sure that when the distributor is put in and it is not properly seated, (IMG:style_emoticons/default/headbang.gif) , it was not and therefore no turning of the rotor and no spark. so simple, overlooked. I also forgot to attach the transmission ground strap once, i dont forget that now. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,789 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I rebuilt a 901 trans in a 71 911 years ago. I did a great job! It had 5 reverse gears and one forward gear.
I put the differential in like a 914. (IMG:style_emoticons/default/headbang.gif) I had to pull the engine/transmission back out to fix it. |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,528 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Well, lets see... I have a tie I think.
1) after checking compression on my engine, I did not realize that the compression hose had unscrewed from the spark bore adapter on the #2 cylinder. I screwed in the spark plug to the compression adapter (they were the same thread and went in easy). I did not notice that the plug was sitting about 1.5inches higher then usual. Drove around pissed off that I had a really bad miss on one of my cylinders after spring maintenance... 2) While doing work on the dizzy, the little spring at the bottom of the distributor shaft somehow went down the tiny hole offset in the dizzy shaft bore and into the engine case. I had to get under the car, lower the nose of the engine, pull the oil pump out and fish out the spring. It was a hot humid day and I was coated in sweat and oil by the time I rolled out from under the car. Zach |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,408 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Have a bunch of these stories, these two got me because it was the same thing on two different cars:
Got my 914-6 back together and test driving little farther from home each time. 2-3 drives out, heater flap box falls off (forgot to tighten clamp). Couldn't get it off road-side, had to drag it home. Same with my Bug: Tranny swap, 3rd-4th drive and start hearing this clank, clank, clank, tink, clank. Heater box lever fell off dragging by the cable. Forgot to put the retaining spring on. (IMG:style_emoticons/default/dry.gif) Made me giggle. Both times, heater cables saved my parts for me. (IMG:style_emoticons/default/biggrin.gif) |
76-914 |
I rebuilt a 901 trans in a 71 911 years ago. I did a great job! It had 5 reverse gears and one forward gear. I put the differential in like a 914. (IMG:style_emoticons/default/headbang.gif) I had to pull the engine/transmission back out to fix it. That's hilarious. Did you say any bad words? (IMG:style_emoticons/default/lol-2.gif) |
ClayPerrine |
I rebuilt a 901 trans in a 71 911 years ago. I did a great job! It had 5 reverse gears and one forward gear. I put the differential in like a 914. (IMG:style_emoticons/default/headbang.gif) I had to pull the engine/transmission back out to fix it. That's hilarious. Did you say any bad words? (IMG:style_emoticons/default/lol-2.gif) Lots of creative new cuss words about my intelligence. |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,033 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
1979 had a 914 sold and promised the guy a clutch so he could pick it up the next day did it myself (used to be able to change the clutch assembly in 45 minutes) got the job done and tried to start the car, turned over slowly. Thinking it has a weak battery I put a battery charger on boost and tried again, still slow start and then smoke started to come from the center tunnel. Found out that I had melted the accelerator cable inside the tube. DISASTER!!!!!!! Spent the whole weekend cutting the tube out of the center tunnel and replacing it. I had forgotten to reconnect the rear transmission ground strap and the starter was using the accelerator cable as its ground. One of the first things I thought of when writing the book 914 "tech tips 700" In fact I put it in two different places!
Lo-Fi Version | Time is now: 7th September 2024 - 05:42 PM |
