> 914World Classifieds Rules
> Also, WTB 2.0 Smog Pump and all that.
gnomefabtech
post Mar 18 2023, 07:45 PM
Getting a 76 road worthy in Cali (IMG:style_emoticons/default/lol-2.gif) so I need a smog pump and all the tubes etc..
Let me know what you have.
Thanks
brant
post Mar 19 2023, 07:09 AM
I’ve got the pump and hard lines
Will get some photos for you
brant
post Mar 19 2023, 08:02 AM
lots of pictures
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
technicalninja
post Mar 19 2023, 09:40 AM
Boy, am I glad I don't have to use that stuff on my 75 Federal spec car...
That is the first time I've seen ND (Nippon Denso) and Bosch share a parts sticker.
Proves the OEMs will sleep with anyone...
That will be a rotary vane pump.
I'd take that apart, grease the bearings and clean up the cases and the internal parts before I put that back into service.
Parts for that pump might be "hen's teeth" to acquire. The bearings will be able to be purchased from a bearing supply using the numbers on the bearings/seals.
burton73
post Mar 19 2023, 11:34 AM
burton73
It may be me looking at this, but the sacrificial rubber part looks like it's broken on this part
I had a 76 car and when the pump froze it broke this sacrificial rubber part this is the part that connects to the crank. If I'm remembering correctly the part has a metal plate on the end where you bolt up the 3 bolts.
Best Bob B
brant
post Mar 26 2023, 10:02 AM
QUOTE(burton73 @ Mar 19 2023, 11:34 AM) *
Best Bob B
It’s starting to come apart
Not separated yet. But needs the repair that all of them need these days
Still pretty complete system with mounting brackets/hardware
Never heard back from original poster
Plan to start a separate add and list this soon if anyone is looking
gnomefabtech
post Mar 26 2023, 05:46 PM
I think I might be able to get away without adding this stuff. Stand by.
ssuperflyoldguy
post Mar 26 2023, 09:28 PM
I believe I have most of the stuff, gotta start pulling it out. My spider is good, I remember losing one on my 76 bus and it was impossible to locate one 30yrs ago
Super90
post Mar 27 2023, 03:14 AM
I have a 75 CA Spec and need the sample pipe that runs from the egr valve you have pictured with the square flange to the muffler area port. Its sort of L shaped, has a welded tab to bolt it to muffler, and 2 bolt square ports at each end. Any help anyone?
Thanks, George
- Lo-Fi Version Time is now: 2nd January 2025 - 07:23 PM
